Airbag.and overheating problem
08.05.2020 14:57 # 1
GiTaRRa
a friends mrb, I have to ask for your information about the problems that we don't know or do not happen to us because every person will know everything.
My airbag was broken, I bought a new airbag, it was installed smoothly because it did not explode at the time of the accident. >
also the vehicle sometimes overheats that I don't use it too fast, I have a water problem or have a different problem. I do not want, I am waiting for your answers ..
08.05.2020 14:57 # 2
GiTaRRa
Does anyone have any knowledge ???
08.05.2020 14:57 # 3
selfat8
Airbag problems can be caused by many sensors, brain electricity etc. Very difficult fault detection without plugging into the computer.
For the temperature, the fan hurts in the air. It is necessary to look at the radiator water, what color is the color of the glass, wash the water with antifreeze water, or you can make them inside the engine and the radiator.
08.05.2020 14:57 # 4
I think it is necessary to introduce the new airbag to the ECU, as the friend says. so it doesn't end with installing a new heat. Also, it is necessary to control the cooling system completely. There is a lot of reason for overheating. Apparently you don't have enough information. I think you should go to a master with that pain. it sounds short already. A good short care makes you comfortable for a long time ...
08.05.2020 14:57 # 5
oguzhan29
Show the airbag to the airbag or the service. The vehicle can decrease the water.
08.05.2020 14:57 # 6
GiTaRRa
I understood the airbag friends, I asked that it had to be connected to the computer when it was asked ... it was okay, I couldn't understand the heat problem, recently the heater was cracked, poured something in the form of ash into it, whatever happened was closing the gaps, then the industrialist went to the car where he stood, and went to the circulation. I stopped the vehicle, then I looked at the road, the light was on, I pulled to the right and kept it in idle for a while. I went to the road, I went up to 10 km recently. prior to
