AIRBAG AND ACCELERATION PROBLEM
08.05.2020 19:17 # 1
nicea
MERHABALAR DEAR FRIENDS FIND YOUR NEW AGREE FIRST I WOULD TŞKLER FOR YOU ARE ŞİMDİDEN Aids'm 206 2004 X-Line on the way CLUTCH PRESSURE to stall GOING AIRBAGS not OFF B USTA Liked TAKE ME BSI BRAIN REPLACE will SAID THE SAME TIME THE HANDS are ACCELERATION DOING between THIS ISSUE OF LIVING MUST HAVE HELP WOULD SAA your SEVİNİRİM
08.05.2020 19:17 # 2
The airbag problem is caused by the airbag wrap and the underarm sockets. If the car is LPG, there is a problem with its settings. It sets a good master. I don't know much about the indicators, whatever I say would be a lie. I also looked at the vehicle master error codes and connecting the vehicle to the computer.
08.05.2020 19:17 # 3
themurat54
I have the problem of stopping when I press the clutch, usually when the clutch brakes, but not always. I showed the master to the LPG master, connected it to the PC 3. The contact problem appeared in the injection. It was like a new injection.
(Injection, do not interfere with the injector, the hump of this lpg was injection, I may be confusing the name in the injector :) themurat54 2015-05-21 14:07:13
08.05.2020 19:17 # 4
fætih
If there is egr, stopping is from it or idling engine.
the airbag lamp may illuminate through the bandages and the brain. Have them checked, they may have even closed the previously opened airbag. indicators are faulty. The new ones are broken down between 200 and 250 TL.
08.05.2020 19:17 # 5
nicea
Thank you for your help.
