airbag, abs, passenger airbag fault
08.05.2020 13:58 # 1
Hello friends.I am a user of pug 307. The problem is that while on the move with the car, I first get the airbag fault and continue to use the car, then it gives the airbag fault and enson also gives the passenger fault fault. I stop the vehicle and when I try to start it again, the ignition turns and clicks and the starter does not press the vehicle does not work, I always stay on the road I showed a few people they changed the battery, they connected the computer, the fault it gave "system voltage supply signal is low" but we still haven't been able to repair the fault. or if someone has the same thing, I would be happy if he shares his information ... thanks in advance ..
08.05.2020 13:58 # 2
While writing abs fault verior after airbag fault, I have written the airbag fault twice instead of abs.
08.05.2020 13:58 # 3
hasimayaz
How many models are the vehicle + are you the first owner?
if so, did the vehicle ever go to service due to ecu malfunction ?? This was the chronic problem of 307 .. The problem was resolved with Ecu update i ..
08.05.2020 13:58 # 4
vehicle 2003 model I am the third owner of the vehicle, I do not know if the ECU malfunction did not know if this malfunction has cooled me from pug. i am surprised
08.05.2020 13:58 # 5
sinan-s
A very strange problem..307 often very problematic cars already ... There may be a malfunction in the starter dynamo.
08.05.2020 13:58 # 6
When I turn the ignition 1 time, the torpedo light is on, but when the vehicle starts, the right and left lights on the torpedo and the rearview mirror do not light up, I think there is a problem in the electrical installation.
08.05.2020 13:58 # 7
sinan-s
When I turn the ignition [QUOTE = mcetinn] 1 time, the torpedo light is on, but when the vehicle is running, the right and left lights on the torpedo and the rear mirror are not lit up, I think there is a problem with the electrical installation [/ QUOTE]
I would say sell and get rid of you.
08.05.2020 13:58 # 8
I think I will think of selling it if it gives the same fault again when I make the fault.
08.05.2020 13:58 # 9
Press the Electric Reset Button inside the Engine.
Try it again if the same problem occurs.
Connecting the Problem to the Electronics.
