Air sound comes from the brake
08.05.2020 17:26 # 1
Gururtr
Hello,
I have a 308 hdi premium vehicle, I feel a notable sound after driving for a certain period of time with the vehicle (when the music is off), when I press the brake as tıssss, the sound is cut off. I wanted to consult. Thanks in advance.
08.05.2020 17:26 # 2
qqyyxx
I had this sound in my clio vehicle, while the vehicle was idle, it was also silent when it was pressed to the gas and constantly whispering when it was moving. The service was said to originate from the restanhaus. It is said that there will not be a problem after the fires do not harden.
08.05.2020 17:26 # 3
Gururtr
Hello there,
A tuning friend said the same but I couldn't trust it. There is no problem with my brakes, it is extremely good but this sound does not scare me.
08.05.2020 17:26 # 4
qqyyxx
When the vehicle was stopped, it normally hardens when pumping the brake several times & nbsp; but in me it was only hard to press the brake once. If you want to try it, if the sound we mentioned is the same, it is caused by rstnhus. I do not think it will be a problem, but the brake is not neglected.
08.05.2020 17:26 # 5
ondercan
a sound with a sound of 308s. servo (air tube) den.but should not be problem with braking.If it changes, the sound will go away.
Good luck with.
08.05.2020 17:26 # 6
Gururtr
Hi, yes, usually these problems occur. There is no hardening in the brake in 308s, even when the vehicle is at a stop, it hardens in 3 or 4 pressures. Let me take a look again ..
08.05.2020 17:26 # 7
plawert
Westinghouse might be missing the air
08.05.2020 17:26 # 8
Gururtr
What should I do ?
08.05.2020 17:26 # 9
plawert
You have to check that the brake work does not come to a disruption
08.05.2020 17:26 # 10
Serkan
[QUOTE = ondercan] is a premiere sound with 308s. servo (air tube) den. master, listen to him I think
