AIR PROBLEM FROM PEUGEOT 208 WATER TANK
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 21:00 # 1
fatih.tosun
If everyone is interested and answered, it is very acceptable.
There is a small air leak from the lid of the water tank when the temperature rises above 95 in my car. it does not overheat. cover was changed. But the same is what you think is the problem and which master should I take. I'm in the Mediterranean region, I would appreciate if you give information about the masters on the side of Afyon Isparta Antalya Burdur.
08.05.2020 21:00 # 2
First of all, welcome to us. then the problem is not from the cover, you will need to change the replacement water tank. If I don't have a vehicle lane, it's diesel.
08.05.2020 21:00 # 3
fatih.tosun
vehicle 2012 model 1.4 diesel
08.05.2020 21:00 # 4
My teacher should not come out of the diesel unless it is too tight on 95 degrees, and the water temperature should be checked digitally by connecting with the OBD device. The mouth of the reserve water tank may be deformed. As pressure increases, there is the possibility of air leaking. Is there a situation in the vehicle such as water drop or oil drop smoke discharge. Does the vehicle see 95 degrees in motion, or will it stop and go?
08.05.2020 21:00 # 5
fatih.tosun
Unless you stand up or move on, 95 does not go over it unless it is very difficult. There is no such thing as water reduction, fat burning, smoke extraction. If I take it to their service, they would exactly detect the problem. Thank you very much for your interest.
08.05.2020 21:00 # 6
You're welcome. They find that if my teacher is a good service, they want a fee between 100-200 TL for the detection of the fault. If it does not exceed 95, there is no problem, hodja.
