air pollution prevention system malfunction
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
21.07.2021 17:32 # 1
45plaka
Hello,
2015 We have been dealing with an air pollution prevention system malfunction in the 308 Active vehicle for about 2 years.
We have not filled the Ad blue tank fully. We cleared the fault and after a while it started again. The car has no other problems, it works like clockwork. We were going to change the ad blue tank as a last resort, and we placed an order... meanwhile, since the vehicle was always under a tree, the front wipers were constantly filled with dry leaves. One day we opened the hood to thoroughly clean the leaves, and while cleaning, we noticed that the rain channels in the corners were clogged. After cleaning it thoroughly, the fault was cleared. We couldn't establish the relationship, but it's free to try :)
07.08.2021 23:05 # 2
Bun Al
I will try. I have the same fault with my vehicle. SERVICE and urea warnings are displayed, exhaust system failure is written on the screen and on the first run, and then they go out, but service and urea warnings are constantly on.
07.08.2021 23:07 # 3
Bun Al
In my 2015 308 Allure, the screen turns off from time to time and then comes back. If anyone has faced such a malfunction, I would like to know their experiences.
08.08.2021 13:41 # 4
Bun Al
2015 -308 Alure I poured water into the said water channels in my vehicle.
Thank you for the information. I hope it doesn't burn again
08.08.2021 13:43 # 5
Bun Al
What does the warning of low oil pressure in 2015 - 308 mean? Thank you to those who will share their knowledge and experience.
20.09.2023 11:24 # 6
smazlum24
My car also had an engine failure and an AdBlue problem. We removed the tank. The electronic board was submerged in the fluid. The pump had blown. We cleaned it and replaced it, hoping it would be fixed, otherwise the tank would need to be replaced. Since they had flashed new software into the ECU, we couldn't even cancel it. It was a complete problem.
06.06.2024 23:05 # 7
osmangdkk
Hello sir, in which city and by which technician did you have your AdBlue tank repaired? Also, when it gave a warning, were the Service + Engine + Urea icons constant or flashing? I would appreciate it if you could provide some information.
