air intake kit help |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 19:00 | # 1 |
| 08.05.2020 19:00 | # 2 |
I am thinking of taking anybody from this system. Please take the help of emergency aid, I will take a long road. I have removed the air filter.
| 08.05.2020 19:00 | # 3 |
does anyone ever use this system
| 08.05.2020 19:00 | # 4 |
muro_60 |
You can use it. No problem, I don't have water or something. If you have LPG, you can install it and adjust the values. The values will change.
| 08.05.2020 19:00 | # 5 |
the car burns too much then I will not install it if I do not have to, but as I said, the lower boiler is canceled
| 08.05.2020 19:00 | # 6 |
muro_60 |
When you put it on, the burning work actually stems from us. |
| 08.05.2020 19:00 | # 7 |
I think my friend has the same engine in our vehicles, 1.6 110 of them, I think you should find the air filter in them, I don't ask you, I do not use the vehicle at high speeds, I do not like it in the sound, does it force the car at low speeds. bust :)
| 08.05.2020 19:00 | # 8 |
muro_60 |
No, there is no water coming in. The hood comes in front of it. Drek is not open, so no fear, he makes snoring when he gives the first gas. If you do not press it, the sound will not come out, but sometimes the horn will disappear when he does not eat on slopes. Is there a problem with your hoodmaster? If you are a user, I prefer to stay orgy
| 08.05.2020 19:00 | # 9 |
I use it calmly, I rarely drive the car to high speeds, we have 206 of you, there is another silencing hood after the big ish * tmal air filter box, there is another pipe that goes into the left fender, it is a cold air system, supposedly my hood is broken, I press it on a broken day, whatever it is. I noticed that broken, maybe there is 2 liters of water, we have replaced the air filter, and we changed the filter with the Iranian glue, and then I did not want to overwhelm that part of the broken masters in the same way. I said, what are you doing? I shouted, I called, I take it out for the first time.
| 08.05.2020 19:00 | # 10 |
We searched the part of the dealers do not have room diyolar gelcek turkey, france 1 month found diyo gidedec a rainy weather I'm in a hurry in the way of it actually
| 08.05.2020 19:00 | # 11 |
muro_60 |
Buy it, you will have no problem, use it, 140 TL is left, if I am not mistaken. I have never been to the mechanic, I do everything myself.
| 08.05.2020 19:00 | # 12 |
just like it is very hard all of them are cunning, take the open air filter and put it on it, thanks for your advice, thank you very much
| 08.05.2020 19:00 | # 13 |
muro_60 |
[QUOTE = 206quik09] just like it is very difficult all of them are cunning open air filter take it, put it in place, you have enlightened me very much because of your advice. thin enters into thin ones. don't worry too much everything :)) don't forget to make gas adjustment
| 08.05.2020 19:00 | # 14 |
: D nice word I will have one more question. Does this oil breather hose have access to this kit?
| 08.05.2020 19:00 | # 15 |
muro_60 |
[QUOTE = 206quik09]: D nice word I will have one more last question. Does this oil vent hose have access to this kit [/ QUOTE] yes, ask again when buying
| 08.05.2020 19:00 | # 16 |
muro_60 |
you can get it http://www.n11.com/peugeot-206-hava-filtresi-kiti-carbon-p36322300
| 08.05.2020 19:00 | # 17 |
muro_60 |
it was cheaper :)) http://www.n11.com/peugeot-pejo-206-carbon-karbon-flitre-kit-filitr-p13098632
| 08.05.2020 19:00 | # 18 |
Thank you very much :)
| 08.05.2020 19:00 | # 19 |
muro_60 |
[QUOTE = 206quik09] thank you very much:) [/ QUOTE]
| 08.05.2020 19:00 | # 20 |
I will search the market tomorrow, I hope that this week, the fuel will not increase, this system is getting colder.
