Air intake
08.05.2020 14:57 # 1
Gogorok
2004 Model peugeot 307 1.6 engine petrol.
I will drain the coolant.
When refilling, I will put the water out of the overflow container.
Do I need to do any bleeding.
If so, how to get air.
Thanks in advance.
08.05.2020 14:57 # 2
When you drain the water, it will eventually get air inside. of course you have to get air. There are air intake caps in the heating hose and the area where the thermostat is located. you can perform the bleeding process from these covers ... you should also put yourself in good water with antifreeze. Get plenty of it. There is no harm to benefit ...
08.05.2020 14:57 # 3
Gogorok
Thank you for answering.
We will add 2.5 liters of antifreeze plus pure water.
Can I learn the ventilation points in more detail?
For example, "There is a screwdriver head screw on the hose 15 centimeters from the right edge of the radiator", etc.
08.05.2020 14:57 # 4
[QUOTE = Gogorok] Thank you for answering.
I will not be able to explain that in detail because I did not get through 307 ...
08.05.2020 14:57 # 5
oguzhan29
Yes, the brother will come in. If you can't do what gogorok says, take it and change it.
08.05.2020 14:57 # 6
Gogorok
The bleeding area is screwed on the hose, which goes from the engine into the vehicle, on the heater hose at the rear of the engine.
