air flow meter - emergency aid
08.05.2020 17:33 # 1
oguzhan53
friends plugged in the air flow meter while the engine of my vehicle was running and turned on the malfunction lamp. There is an article called depollution system faulty. How can I solve this problem? thanks to everyone in advance.
08.05.2020 17:33 # 2
rolandgarros
If you are removing the battery terminals, remember to follow the 3-minute rule. you will see if you search in the forum. Wink
08.05.2020 17:33 # 3
oguzhan53
Thank you guys, for your help, can you tell us in detail how to remove this pole head and put it on, how many minutes will I wait in a pole like +, - exactly. oguzhan53 2013-05-01 22:52:28
08.05.2020 17:33 # 4
oguzhan53
thank you so much.
08.05.2020 17:33 # 5
samet206
If there is really no malfunction, you will be extinguished after 200 km.
08.05.2020 17:33 # 6
ZP105
shame why you removed the plug
08.05.2020 17:33 # 7
rolandgarros
It is certain that it was not dismantled while standing still LOL
08.05.2020 17:33 # 8
ahmet_bjk
Why is it going out after 200 km?
They want to go to the service if you want to delete it, they charge too much. They delete at a more affordable price in the industry ...
08.05.2020 17:33 # 9
oguzhan53
Guys I completely disassembled for a purpose. I thought that the flow meter could not be working, it was a bit heavy in the overturning of my car recently. I removed it for control purposes. So will this lamp turn off when I connect it to the pc one day?
oguzhan53 2013-05-02 16:59:41
08.05.2020 17:33 # 10
ahmet_bjk
Did you do anything to get it out? Did it go out by itself?
If it is extinguished by itself, it will not light again.
How did you test whether it works or not? What needs to happen when you pull the plug? Although the fault light is on in my vehicle, I want to test it.
08.05.2020 17:33 # 11
oguzhan53
When the lamp was on, I immediately went home and wrote in the forum about 2 hours later, I went down to disassemble the pole, I pressed a starter before removing it, I did not warn, oh I said. When I searched in the forum, it was written that the vehicle could do from this piece when it seems to me that there is no old wreck, but when I unscrewed the socket, the role of the vehicle was different, I realized that it did not take over. oguzhan53 2013-05-02 21:11:57
08.05.2020 17:33 # 12
ahmet_bjk
Did you shoot while it was running, or did you run it after shooting?
