Air flow meter.
08.05.2020 17:32 # 1
ahmet_bjk
The air flow meter (flow meter) turns on the malfunction lamp, but there is no oddness in the engine's operation. div> & nbsp;
What are the differences in engine operation when the air flow meter fails?
08.05.2020 17:32 # 2
hsnsnl
If you insert the air flow meter and clean it
08.05.2020 17:32 # 3
tellotello
[QUOTE = ahmet_bjk] The air flow meter (flow meter) turns on the malfunction lamp, but there is no oddness in the engine's operation.
When the air flow meter is defective, what are the differences in the engine's operation? Best of all, if there is always an uphill slope, it manifests itself more difficult than before. This was what happened to me. However, it was very strange when I looked at it from the computer, but it did not turn on the fault lamp (said it might be a master). In addition, another master said that this piece will not break down easily, perhaps it will not be necessary to change if it is cleaned, usually it would be a problem when the air was kept and the socket was checked. Get well soon.
08.05.2020 17:32 # 4
ahmet_bjk
I will try to clean it as soon as possible ... Thanks ...
08.05.2020 17:32 # 5
fatihgg
Do I have a friend who can make the exact point where the air flow meter is at 307 1,4h, I want to check it out and clean it.
08.05.2020 17:32 # 6
ahmet_bjk
If there is a socket piece between the pipes going to the air filter, it is probably that air flow meter.
