Air filter tube
08.05.2020 15:19 # 1
Burak07
Good evening everyone :)
I often open the subject, maybe you get bored, or do you still have those who say you have a wow and a troubled car: P
My question is, I have an open air filter and the pipe of the tractor: I could not find a pipe other than the P possibility limitation, I want to change this place. When I talk to my friend, he said that it will not be very efficient and it will draw hot air, but we do not know where to buy the pipe.
08.05.2020 15:19 # 2
EmRe26
yea burak krdşm. Let's take comments from our brothers. I said it would draw hot air because it is so close to the engine. Let's see what our brothers will say. We expect them to inform us with their vast ideas ..
08.05.2020 15:19 # 3
Burak07
: S nobody answered
08.05.2020 15:19 # 4
my brother, you have the opportunity to find a lot of sites like gone, there are longer and shorter noses, very cheap 30-40 TL.
08.05.2020 15:19 # 5
tigerland
I bought 15 tl z tech flexible pipe 1 meter longer I still use it I installed the air filter away from the engine :)
http://www.hepsiburada.com/liste/z-tech-esnek-hava-filtre-borusu-70mm-8181/productdetails.aspx?productıd=otelf8181&categoryıd=20024754
08.05.2020 15:19 # 6
tigerland
Also, is that little pipe idle? put a crank filter on it, don't keep it idle.
08.05.2020 15:19 # 7
Burak07
Thanks a lot for your help and suggestions :) I ordered :)
08.05.2020 15:19 # 8
tigerland
you are very fast :) don't forget to use the crank filter like that
08.05.2020 15:19 # 9
Burak07
yes it looks like: S what's the harm or benefit ??
08.05.2020 15:19 # 10
EmRe26
What is a crank filter?
08.05.2020 15:19 # 11
tigerland
crankcase breather filter, discharges the air in the crankcase, do not use the tip idle, dust escapes etc. Let the friends who know what kind of problem opens you can help :)
08.05.2020 15:19 # 12
Burak07
The tip is banded: P stands just like that :)))
08.05.2020 15:19 # 13
Burak07
The pipe I ordered yesterday came and when I said I would extend a full fiasco pipe a little bit, the pipe shattered in my hand: I am thinking of returning S ...
08.05.2020 15:19 # 14
tigerland
Come on, how did you tear it down :)) Thanks to the wires passing through the pipe, it was like 1 year old with a snap fastener. return it back, send a new one :) get past
08.05.2020 15:19 # 15
Burak07
It was very hard and it was torn when I got a little bit when it came: s I was hung up a little and I am adding frustrated pictures
xr07 2011-05-03 10:58:17
08.05.2020 15:19 # 16
tigerland
The material like hard plastic is hanged well :)) I bought 75 mm. When I was tightening, I broke it half as much as the piece that was broken. When opening the hose, just pull it to the left without applying pressure, it is already snapping.
08.05.2020 15:19 # 17
Burak07
:) yes I open it now but unfortunately the hose did not fit :( it is entering the air filter but it is big to the other entrance :( I think I will continue with the old pipe :(
08.05.2020 15:19 # 18
tigerland
Didn't you get 70 mm? You do not need to continue with the old apparatus, you can connect with the adapter. where is the other entry :) i think you bought 76mm you use the connector then you got it without measuring immediately like me: D
tigerland 2011-05-03 12:27:24
08.05.2020 15:19 # 19
Burak07
Currently like this
I made up, now I combined it with the parts of the old air filter and did something but it still stands in the same place. xr07 2011-05-03 13:02:34
08.05.2020 15:19 # 20
Burak07
How do you think I should use it? What are the harm and benefit?
Page : / 2
