Air filter hose
08.05.2020 19:51 # 1
3saniye
Hello friends;
I had the prins technomax lpg kit installed on my 308 1.6 vti vehicle (2008 Model) 2 days ago. But the master removed the hose of the air filter in order to install the regulator. So the voice of the vehicle got a little rough. would it be a problem if a smaller diameter pipe was installed instead?
08.05.2020 19:51 # 2
I think there will be little difference in fuel consumption and performance.
08.05.2020 19:51 # 3
GokhaN
[QUOTE = 3 seconds] Hello friends;
I do not think it will be a problem if you install the air inlet duct diameter of the vehicle without reducing it too much.
08.05.2020 19:51 # 4
Cyrus35
There is a butterfly that opens and closes the air inlet in the same width as the channel. I think that as the diameter decreases, the amount of air to enter will cut from the force that will be forced, and I think that a shrink of 1 2 cm will not be beneficial in terms of power.
08.05.2020 19:51 # 5
3saniye
Thanks.
