air filter
08.05.2020 16:42 # 1
sezar206
friends I'm thinking of installing a performance air filter on my vehicle but does it increase the fuel too much? And there are 15 20 pounds of air filters in their all work here? If I bought these, does it fit the vehicle or did I see the apparatus? Do I get it? What advice do friends use?
& nbsp;
08.05.2020 16:42 # 2
The open air filter does not increase fuel. But usually wearers tend to get more gas because they want to get a sound, and so the car feels more lit. & nbsp;
08.05.2020 16:42 # 3
sezar206
On Friday, I burned the car and ran it the next day, went 200 meters from the front of the house, and came as if someone was shaking gas and not eating. When it came, I removed the air filter, there were broken places in the lower boiler that took water, in the `u`-shaped boiler in the part that came under the fender. The air filter was filled with water like a sponge, so what do I say if I disassemble it and install an open air filter?
08.05.2020 16:42 # 4
sezar206
no, my goal is not sound or there is a problem I wrote above. These two happened at the same place, I was amazed at what I was going to do as well as full of water. Today I went to the master, he removed the u-shaped boiler at the bottom, pierced the boiler above him, working with him from the left to the right for now. We also taped the open part at the bottom. I don't know what to do. What do you suggest friends or I'm confused. & Nbsp;
08.05.2020 16:42 # 5
sezar206
08.05.2020 16:42 # 6
It's all up to you.
If you want to install an open air filter, I'd say buy one. If you say I have the original repaired, I think you can find those parts as the exit.
08.05.2020 16:42 # 7
sezar206
I understood thank you. Well, is there any friend who has this problem? When the air filter washes the water area, there is a lot of water left there.
08.05.2020 16:42 # 8
ozaannn
If you buy an air filter, the ones from the inner sunger are destroyed over time. I have been using the air filter for 2 years.
08.05.2020 16:42 # 9
sezar206
Is there any possibility that this open air filter can get water in rainy weather?
