Air filter
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:02 # 1
GokhaN
It is the cheapest and easiest to do. The logic of the event is to make the engine get more fresh air. Normal, standard air filters are made of a paper-like substance and are located in a box attached to the engine unit. This box draws air from the front of the car through a pipe, and this air passes through the paper filter into the cylinders, into the combustion chamber.
The resistance applied during the passage of air through the filter directly affects the air entering the engine. For this, performance type air filters have been produced. In addition to holding dirty air like paper filters, these filters make the engine breathe easier because they pass air through paper filters more easily. These filters are also of three types.
1 In-Box Filter: These types of filters are removed from normal paper air filters and placed in their old places. They are the same type and size as paper filters.
2 Open Filter: This filter is connected to the air inlet of the engine by removing the box that we just mentioned and the pipe that allows it to breathe. Thus, resistance is reduced and air suction is easier.
3 Bolt-On Open Filter: This filter type is considered as the version of the direct filter applied to injection cars for carburetor vehicles. But unlike them, the air is mounted not just on the end of the suction pipe, but directly above the throttle.
Points to consider in practice:
There is a point to be considered in open filter applications. This is that the air entering the engine should not be hot. If an air inlet support is not provided to the open air filter, the filter will not be able to absorb the heated air under the hood, which will degrade engine performance.
The best performer of such applications is to cut the bonnet directly. If a hole is opened on the bonnet, like the Subaru Impreza, with the air filter in the mouth, it will be able to provide a significant improvement in performance by taking the air filter comfortably through this hole. If you do not want to, either for the open filter, you will direct clean, cool air to the open filter through a sufficiently large pipe somewhere in front of the car, or use an in-box filter. However, in-box filters do not have as much contribution as an open filter, which is well applied in terms of performance. In addition, open filters produce a louder and sportier sound than in-box filters.
Advantages, disadvantages
Let's say this when the subject is opened, the only drawback of performance type filters is that they make a lot of noise. If you are a sporty-hearted person, you will like this sound a lot, but it can be a bit challenging on long roads or when your dad gets on the car.
The advantages of the open filter do not end with counting. They increase performance, reduce fuel consumption, increase engine torque at every revolution. Yes, a good open filter application increases the engine power by about 5%, besides, it provides a fuel consumption of around 0.5lt per 100km and also makes the engine stronger at low revs compared to the old one.
When it comes to air filters, the first brand that comes to mind is K&N, besides, there are many brands such as EAFY as Turkish production and Green, Jamex, ITG, RAMAIR in other foreign filters. EAFY, RAMAIR and ITG have come out as the highest performing filters in a test performed by the auto-show magazine in terms of performance. Also, since EAFY is a Turkish brand, it has an obvious price advantage.
Alıntıdır.
08.05.2020 14:02 # 2
OneZeroSix
ignorance will not be burning too much but when combined with exhaust they become a super performance duo!
health sister
08.05.2020 14:02 # 3
canberk
I am thinking of buying an air filter kit for my vehicle (206 gti) soon, but I could not decide which brand to choose, I would be glad if you helped everyone is running an idea, but I did not know which filter to get the best performance and sound, thank you for the information.
08.05.2020 14:02 # 4
FTH
Thanks Gökhan beautiful sharing .. Thumbs Up
08.05.2020 14:02 # 5
pug307_26
The open type filter has nothing to do with the fuel situation such that the closed type never increases more air emissions than the level calculated from the original R&D results, but this is disproportionately why if the air is absorbed hot from the engine, it is disproportionately unplugged from the old type without buying a suitable cai kit. Contrary to expectations as performance improves, this provides a decrease in fuel. let's 2010-06-09 01:51:52
08.05.2020 14:02 # 6
karayel1984
I guess we cannot use the open air filter in diesels, or are there any people trying?
08.05.2020 14:02 # 7
bbcb
I have recently checked that they said that more than normal air was entering the engine. I use the filter of the kn. The performance and sound of the vehicle is super +3 HP cheap and comfortable performance
08.05.2020 14:02 # 8
yigithan34
Greetings ... I think I do not understand, is there only an increase in fuel?
08.05.2020 14:02 # 9
GokhaN
[QUOTE = yigithan34]
Of course, there is increasing fuel, the minimum increases around 30 kr.
