AIR CONDITIONING SET OF HOT AND COLD
08.05.2020 21:27 # 1
Pejocan
Hello Peugeot Family I'm facing a problem LOL
My car peugeot 307 2006 model premium known air conditioner is digital, has a minor problem.
This problem was that the air conditioner repair kit was ordered last year on the internet.
the other day I said let me take the air conditioner HI (from hot) LO (cold) there is no problem on the right side, the driver on the left side was stuck in the hot air, even though it was mounted on the air conditioner steering kit, I went to my mechanic, he dismantled the engine, the engine is not a problem, he said that the vehicle was attached to the engine on that chest. I tried to turn it, I couldn't see that much detail. Even though this gear was broken from the inside, the motor does not take the direction of the cover from the air conditioner boiler, etc. He said that this problem exists in the peugeot 407 307, or my mechanic did not reach because he did not fully understand? I would appreciate if anyone knows
If it is broken internally, the chest of the vehicle is removed and they removed the air conditioner boiler. Confused
If there is no probl emi of that gear from the inside , I will take it to anyone who understands this work in gaziantep etc. Thanks in advance. Good forums everyone
the gear that the mechanic calls internally broken.
the Pejoc 2020-02-10 16:50:30
08.05.2020 21:27 # 2
I think it is hard to break inside, hodja. already attached to that threaded pole cover. In addition, you can see the part details here.
sonerkyl 2020-02-10 15:19:39
08.05.2020 21:27 # 3
Pejocan
I uploaded a picture of the piece I said.
Is the round gear in this console not easily broken from the inside?
So why not change from hot to cold even though the air conditioner repair kit is available?
08.05.2020 21:27 # 4
Does the engine that drives the steering sound sound like my teacher is sounding? gotta check it out. In addition, when you make the guidance manually, there is a hot cold transition.
08.05.2020 21:27 # 5
Pejocan
The engine turns, the white gear in the air conditioner repair kit, which is mounted on the solid, turns around with the gear in the picture above.
08.05.2020 21:27 # 6
Strange situation, hot water is coming into the heater core. did you check it
08.05.2020 21:27 # 7
Pejocan
The hot is already in the heat I can't get cold.
08.05.2020 21:27 # 8
kaan206
[QUOTE = Pejocan] Hello Peugeot Family I'm facing a problem LOL
R
Spin the gear with a tool without damaging it manually or without damaging it.
There is a problem with the button in the tprpido
Bn in the summer, cold winter, I get hot and hot with my hand.
