Air Conditioning Maintenance
08.05.2020 14:00 # 1
The air conditioning, which was forgotten during the winter season, is one of the most needed equipment for the car when the summer comes. However, the neglected, neglected air conditioning system during the winter can cause problems when it is used continuously.
It is recommended to control the air conditioner system three times a year in order to work properly. The air conditioner's radiator is affected by impacts such as stones and bumps, and the discharge of gas in it draws attention as frequent failures. It does not perform its duty without gas for a long time or runs with missing gas, and causes the damage to increase and repair costs to increase. Gas sitting or gas leakage are also among the common problems in the air conditioning system, which is not operated for a long time during the winter months. In air conditioners that never work, the problem is largely due to electrical malfunction, and in air conditioners that do not cool enough even though they are working, this is mostly due to dust accumulation in the evaporator. Since our country is generally dusty in the road conditions, the fact that the pollen filter is not replaced in time causes dust to accumulate in the evaporator where the cooling in the air conditioning system takes place. As the cooled air cannot pass through the air conditioning pipes plugged by the accumulated dust, it is not enough cooling.
Dust particles leak into the evaporator, which is a humid area where cooling occurs in the air conditioning system, causing bacteria to form over time. Accumulating bacteria disturb drivers whose body is sensitive to allergies. It is recommended to use antibacterial spray developed for this job to eliminate bacteria accumulating in the evaporator. A / C disinfection spray; Lawning prevents bacteria, fungi and mold as well as solving problems that micro-organisms can cause. Two types of gases, RI2 and R 134a, are used in air conditioners. R 12 gas, which damages the ozone layer, has been banned from being used in cars sold in Europe since 1995. Instead, harmless R 134a air conditioner gas is used in the ozone layer. It is not possible to use new type of gas in old model car air conditioners, as it causes a big malfunction in the compressor. The air conditioner compressor needs to be replaced in order to use gas that does not damage the ozone layer. However, this process is not preferred due to its high cost. Whichever type of air conditioner gas will be used in the car, it is stated on the air conditioner compressor. The oil used in the air conditioner compressor should also be suitable for the quality of the air conditioner gas. Incorrect oil selection may also cause malfunctions in the compressor.
In the summer, you can get rid of the dirt and deposits that will hinder the operation of the system such as pollen, sports, dust, soil and industrial fumes that have affected the ventilation system of your vehicle.You should frequently clean the vehicle cabin's heating, cooling and ventilation system. The cleaning of this filter is important in terms of cleaning the air circulating in the vehicle and people with allergies such as pollen allergy.
If your vehicle is 2000 model or newer, your vehicle is probably equipped with a cabin air filter, since most of the drivers are unaware of the presence or absence of a cabin air filter, they may have to breathe air that cannot be fully cleaned with this filter which is disrupted. You can find out from the manual of your vehicle. Non-cleaning filters can cause odor in the vehicle and damage the vehicle's heating / cooling system with blockages that may occur.
alıntıdır
emrah 2009-01-09 16:35:08
