air conditioning lighting problem?
08.05.2020 16:56 # 1
cgty86
Guys, I know this topic has been opened before, but I wanted to get advice from you because I can't do the problem myself, a master who can do this lighting problem in Ankara Thank you in advance, who do not want reliable and herpes prices.
08.05.2020 16:56 # 2
cgty86
I forgot to say the panel is analog and no lights are on at the moment, it was lit by a couple of clicks before but none of them are lit
08.05.2020 16:56 # 3
cgty86
Are there any friends from Ankara to help ??
08.05.2020 16:56 # 4
elsoberano
I would recommend the self icon peugeotu. The prices are normal.
08.05.2020 16:56 # 5
cgty86
Is there an address thank you
08.05.2020 16:56 # 6
senol73
Sir, it is very simple to fix your problem, you can do it yourself very easily. Lighting bulbs on the back of the panel may be loose or the cable may be broken.
Even a normal auto electrician can handle your problem for a cheap money. The maximum amount will not exceed 20 lira.
08.05.2020 16:56 # 7
falan
the same problem was with me. I removed the panel, changed the bulbs, it was improved .. you can do it yourself with your hand.
08.05.2020 16:56 # 8
cgty86
I do not want to touch the plastic parts, but I do not want to touch the nail plate, I do not want to touch the nail plate.
08.05.2020 16:56 # 9
ergun1974
hello my friend
I work in a factory producing car air conditioners
there are 2 lamps on the back of the control panel, these are the night lights or the parks come on. the socket that burns those lamps is probably out of place, or you need to change the lamps. It is not a huge problem, any electric master can do it.
& nbsp;
08.05.2020 16:56 # 10
zgr
[QUOTE = cgty86] my hand is prone but I do not want to touch the plastic parts very much, I want to have a nail nail broken, remove it, do not throw it in the trash, because I want to make the die work somewhere because the complete tape panel is tied up, the rip-off tape is dismantled & nbsp;
believe that a master will not take care of you as you do while doing disassembly. the masters smash the pieces. I am not looking when I go to the master while the parts are being removed. I'm burning.
08.05.2020 16:56 # 11
cgty86
thank you everyone for their interest
