Air conditioning grills broke down
08.05.2020 20:28 # 1
hasayduman
Hello,
The grills that direct the air inside the air conditioner are broken, is there any repair or should you buy a new one?
Sygun.
08.05.2020 20:28 # 2
tolga.onal
The master comes down, pulls it down, pulls it up and pulls out.
08.05.2020 20:28 # 3
hasayduman
Yesterday evening I removed the right side but I did not see a system to replace them,
[QUOTE = tolga.onal] Master, you can pull it down and grab it when you pull it out. They can snap together, you can tilt it so you can sit the grills inside it.
08.05.2020 20:28 # 4
kilic46
From the side, it turns out that it opened the gap without crushing with a flat screwdriver. And the panels that guide your direction all seem to have fallen down.
One should not drop the stabilizer plastic on both sides when removing and inserting it. I thought it was shaking very much, instead I had set another plastic. kilic46 2017-07-22 18:20:40
08.05.2020 20:28 # 5
Peugeot35
If the pieces are in place, you should wear them, you can wear the nails.
08.05.2020 20:28 # 6
hasayduman
Thank you for your comments, I had it with the tooth out first, now I only saw the nails that you mentioned inside, I just put them all 2 broken,
After a nice wash cleaning, I will stick it with cyclone in the evening and install it in its place.
08.05.2020 20:28 # 7
Selox
Can you take a picture from where you got it?
08.05.2020 20:28 # 8
hasayduman
[QUOTE = Selox] Where can you take a picture of me? Can you drop me too? [/ QUOTE]
I dismantled them all like this picture,
08.05.2020 20:28 # 9
Selox
Eyw bro you are random. :)
08.05.2020 20:28 # 10
No need for a screwdriver.
08.05.2020 20:28 # 11
hasayduman
I washed it with oil remover the day before, it was as if it had not been removed until now, as if it had attached oil inside.
Last night I siliconed the broken legs, replaced the dislocated ones, I hope I put them in the car tonight.
08.05.2020 20:28 # 12
Selox
As Soner said, I disassembled it with my hand and attached it :)
08.05.2020 20:28 # 13
hasayduman
I hardly disassembled it with a screwdriver, the renovation process is over, I put it back last night, it was fine.
08.05.2020 20:28 # 14
the video seems to be very easily dismantled.
[TUBE] vfdkakgeli4 [/ TUBE]
08.05.2020 20:28 # 15
Kocak
You can grab it with your hookup and place it in place it's very easy
