Air conditioning compressor does not start
08.05.2020 20:59 # 1
muhoist
Good luck to everyone, I wanted to make an ignorance today and disassemble the manual air conditioner so that the lamp of the manual air conditioner broke out. When I press the air conditioner, the light is on but the hood looks strange. Kompressor does not start where I may have damaged. Blowing works. Hot cold settings. Direction settings are working. There is a problem in cooling. My request from knowledgeable friends, so I can check all sorts of ideas and thank you again.
08.05.2020 20:59 # 2
muhoist
Don't have friends with an idea?
08.05.2020 20:59 # 3
VUNUS
I have changed the thermostat malfunction, I have changed the air conditioner. It worked spontaneously.
08.05.2020 20:59 # 4
ersinyildiz
First of all, you need to make sure that your action caused it. For a quick check, I would have an electrician check all the fuses, the pressure of the A / C gas and the compressor socket. If there is no problem so far, you can focus on the operations you do. It would be more convenient for you to handle it with an electrician who can follow the circuit.
Get well soon.
