Air conditioning, chirping sound from the heater
08.05.2020 16:53 # 1
Serkan
When the friends use the heating fan in the 1st and 2nd stages, there is a fine chirping sound, most likely it comes from the propeller. doing all of them in hot and cold position ... Serco05 2012-07-06 17:54:14
08.05.2020 16:53 # 2
tigerland
Try air conditioning cleaning sprays will be effective. & nbsp;
08.05.2020 16:53 # 3
Generally, it makes the grazing sound from the engine's ball. So it is necessary to replace the engine completely. It may be necessary to remove, clean-lubricate, and have not changed.
08.05.2020 16:53 # 4
LUCY
I have the same problem in the first stage, it gets sick, sometimes when I turn up the music, Peugeot 206 plastic sounds and various sickening sounds disappear. I can't think of a 206 without sound system. I think it would be beneficial to lubricate it with the oil. If the weather gets better, I will use this process and if I get positive results, I am thinking about photographing how I did it. edited>
08.05.2020 16:53 # 5
Barut
me sounds in the first boot, sounds a few seconds later
08.05.2020 16:53 # 6
muku
I have it in me, I get it directly to 3, then pass it back down
08.05.2020 16:53 # 7
hLL
The same problem occurred in me for 2 days. No problem at 3 to 4. There is sound 1 and 2. : Q What can we do?
08.05.2020 16:53 # 8
peugeotolcay
:) I have the same problem, I pull back from 1 to 3 and then 3 to 1, or sometimes the right foot out there is fist corrected :)
08.05.2020 16:53 # 9
Aziz
If you can reach the engine, bypassing the pollen filter and filled the dirt, keep the air in the fan while working with a compressor.
08.05.2020 16:53 # 10
soner09
If I say I have it, the first is done,
08.05.2020 16:53 # 11
CHK35
I had the same problem. But my air conditioner is digital. It does it when the temperature rises. I think we have to go to the place that is the removal process from here and try it :)
08.05.2020 16:53 # 12
seydisehirli
it comes when I enter the coder in me :)
08.05.2020 16:53 # 13
10URAKAR
Hello Friends,
I have the same voice in the 1st stage, it does not make it in the others. I think there is dirt in the fan part of the vehicle.
how to solve it? "LOL"
10URAKAR 2015-02-12 11:36:45
08.05.2020 16:53 # 14
CHK35
Where Is This Engine Friends Where Can We Tighten This Spray-like thing?
08.05.2020 16:53 # 15
10URAKAR
I guess under the full ashtray I know. it is very hard to reach there .. or you need a skilled person
08.05.2020 16:53 # 16
monalos
There is no sound from the windshield motors, no sound at other levels
08.05.2020 16:53 # 17
BLACK LION
When the fan is not working, I click on the broken road when the engine is cold. When the engine heats up, it sometimes goes away completely. What is the solution? I pressed the air from the outside, but it didn't matter.
08.05.2020 16:53 # 18
sezar206
[QUOTE = Red dream] I have the same sounds when I first start it, it shuts down after a few seconds [/ QUOTE]
I was in the same situation with you, then cut off completely.
