air conditioning and misfire assistance
08.05.2020 20:43 # 1
AhmetSehzade
Hello Friends, my car does not turn on the air conditioner until it reaches 70 degrees
But this does not happen in normal days, after the weather drops below -0, it usually happens. ?
In a sequential system, when it passes from gas to gas, it starts kicking.
08.05.2020 20:43 # 2
gas misfire is likely related to the lpg map sensor and the temperature sensor. In addition, my teacher is not for air conditioning heating. Air conditioning compressor needs to have a certain pressure to be activated, it does not provide minus degrees below 0. I guess you turn on the air conditioner while it is in hot position to defog.
08.05.2020 20:43 # 3
talip206
If it is also on Gasoline, low temperature misfire and exhaust eruption may be due to the coil. It happened to me. When the coil end oxidizes, it cannot conduct electricity in the humid air. When the motor heats, the moisture of the oxide goes away and improves. No need to go to the master to find out the coil failure. Remove the plastic nozzles at the end of the coil, if there is no oxidation, the coil is defective.
08.05.2020 20:43 # 4
AhmetSehzade
[QUOTE = sonerkyl] gas misfire is likely related to the lpg map sensor and temperature sensor. In addition, my teacher is not for air conditioning heating. Air conditioning compressor needs to have a certain pressure to be activated, it does not provide minus degrees below 0. I guess you turn on the air conditioner while it is in hot position to defog. [/ QUOTE]
Normally it opens in every vehicle, not mine, but .s
It does not blow, does not dissolve, so I have to run the car for 15 minutes for the 10-minute road.
So that I can unfreeze the ice today.
08.05.2020 20:43 # 5
monalos
Are you taking the air conditioner to the cold and turning it on or taking it to the heat?
When it gets into the heat, the compressor does not come into operation.
In addition, if there is no gas in the air conditioner, if you put it in cold, the compressor will not start
It does not open the air conditioner in any vehicle and the interior of the vehicle does not heat up. monalos 2018-01-30 12:59:49
08.05.2020 20:43 # 6
onlycihan
It happened to me on my 206 vehicle last winter. I was turning on the fan on a cold morning, but when the ac button was pressed, the relay did not sound and the lamp of the ac did not light up. When the clock went on and the weather got a little warm, I tried it again from my curiosity.
