AIR CONDITIONING
08.05.2020 19:51 # 1
ARDADOGAN
Friends burning everywhere known turkey hot air conditioner in my car idling in binince warm blows and does not cool the inside of the car to an album namely air conditioning performance at 5 wonder conditioner out of 10 for me in one such problem varmıdır knows to find a cure yaşayıpd the 307's air-conditioning performance is how.
my car 2007 307 1.6HDI
By the way, there is gas in the air conditioner, there was a leak in the radiator last year and I just changed the pollen. I wanted to suggest your suggestions without going to the master.
08.05.2020 19:51 # 2
ahmetemir
If it blows beautifully on the road, take a look at the fan. When you press the air conditioner button when the car is in idle, you will hear the sound when the fan is activated when you step 1 or depending on the load. I did not know if I bought it for 20 seconds, it blows 1 min, it blows again after 2 or 3 minutes, it cuts again, one step is behind.
08.05.2020 19:51 # 3
gokhanyalcinkaya
I have no problem working, but I melt until it cools down. I went 15 km etc, but it got cold the next day. The pollen has just changed, I just pressed the gas, and the control was done, but I did not like its functioning. As you said, brother 5 out of 10. When the air conditioner works, the car is having a hard time, where it makes a horrible noise, and the traction drops dramatically. How about that?
08.05.2020 19:51 # 4
KIZILASLAN
If [QUOTE = ahmetemir] blows nicely while driving on the road, take a look at the fan. When you press the air conditioner button when the car is in idle, you will hear the sound when you step on the 1st stage or depending on the load. there is open to the air conditioner, I did not know if I put it to the full level, it blows 1 min, it cuts 2 or 3 minutes it blows again, it cuts again, one stage is behind, there is still no problem in other levels. [/ QUOTE]
Have your vehicle's battery checked in 307s. If the battery's power is insufficient, the vehicle will turn off some functions and turn it on again when the power is recovered.
08.05.2020 19:51 # 5
ARDADOGAN
my battery can't be from 2 month battery
As you said, when I went to Ankara, a master dismantled and repaired it, he said it became better than before. There is nothing in the gas radiator of the air conditioner.
Last year, I had a friend laguna 98 model from my car 8 10 years younger man opened the air conditioner. okay I want it to blow up to an albea, if not as much as it is ...
08.05.2020 19:51 # 6
talip206
peugeot usually heats up quickly cools down quickly. This is generally the case
even most of the French vehicles are. my 206 is making it icy in 5 minutes. I think you should have a check again. Friends who use 307 are writers though. I first suspect the pollen filter but you have changed Maybe there may be a problem in the orientation or hot cold orientation section.
