air conditioning
08.05.2020 15:24 # 1
berk2309
friends, I just asked, I could not get an answer when I was working on my air in 307, the reason for this situation and the solution for everyone is 100 TL.
08.05.2020 15:24 # 2
insomnia
[QUOTE = berk2309] friends I just asked, I did not get the answer, when I was working on my air in 307, why is it the reason and the solution for everyone? 100 / TL jammed diode is not the problem, exactly what causes malfunction?
I think I go to a air conditioner and take a look at the gas pressure values with the manifold
08.05.2020 15:24 # 3
vbmaster
Does it stop working in the heat?
08.05.2020 15:24 # 4
berk2309
No, it does not stop in the heat, only while it is working on the air. duruyo & nbsp;
08.05.2020 15:24 # 5
vbmaster
If the gas is running low, it often does not work if the clear gas runs out
08.05.2020 15:24 # 6
berk2309
we pressed the gas last year in the summer: D also we did not have a leg or we looked at it
08.05.2020 15:24 # 7
ose
Don't let the engine cool down?
08.05.2020 15:24 # 8
berk2309
fan stops, naturally stops cooling: D
08.05.2020 15:24 # 9
ose
For the first time I hear something like this.
08.05.2020 15:24 # 10
vbmaster
Does the air conditioner turn itself off? Otherwise, only the fan is stopping, and the gas may have gradually decreased even in a small leak. It's a measure, but they don't take money without measuring ...
08.05.2020 15:24 # 11
berk2309
money is not a problem, now I am reading in Cyprus, I am going to go to Ankara, but I do not understand here, we don't understand the original material.
08.05.2020 15:24 # 12
knockout
I will ask you something when the air conditioner is turned on. How to prevent this when the ignition is turned on or after starting the car and starting the car, the air conditioner works automatically.
08.05.2020 15:24 # 13
berk2309
he cannot be prevented or it hurts according to the weather, he is in me: D
08.05.2020 15:24 # 14
knockout
Turning on the air conditioner on automatically in winter is not interesting
08.05.2020 15:24 # 15
metin
[QUOTE = knockout] I will ask you something when the air conditioner is turned on. How do I prevent it from turning on the ignition or starting the car and starting the car automatically? [/ QUOTE]
If the air conditioner is switched on before stopping the vehicle, it will also turn on when the car is turned on, if you have turned off the air conditioner before stopping the car, the air conditioner will not operate when it is restarted,
By the way, I don't know if the air conditioner is digital.
08.05.2020 15:24 # 16
knockout
unfortunately not digital
08.05.2020 15:24 # 17
berk2309
my auto air conditioner works according to the weather, if it is closed when i stop the vehicle, it works by itself, according to the temperature of the air, for example, if the car did not work at all, today I got into the car and the weather was 30 degrees.
08.05.2020 15:24 # 18
[QUOTE = text]
No text is not like that. I have an event that my friend said. The gun is coming, I will start the car, I am making contact half-way, the air conditioner is on and it will work, I turn it off. The gun is coming in half, I make contact, the ventilation is on, I close it again. Both of them do this even when I turn off the air conditioner-ventilation while the vehicle is stopped. I think this is automatic. Depending on the external heat, it hurts or does not.
08.05.2020 15:24 # 19
knockout
I usually use ACS.
08.05.2020 15:24 # 20
berk2309
If your vehicle is full of beny, even if you turn it off automatically
Page : / 2
