air conditioning
08.05.2020 17:47 # 1
yavuz_0051
I bought my car, my friends, the air conditioner was not working, I filled the air conditioner gas, but it did not cool the pollen filter, the air conditioner comes on, the sound comes out, the air conditioner engine comes into play, the idle falls, the air conditioner pipes come in, but still it does not cool, I took it to the master, he said he did not separate the hot cold button, he canceled the hot entrance of the calender, again something has not changed yet does not cool 99 206
08.05.2020 17:47 # 2
mahmutbasaran
Sir, the same problem was with me, the air conditioner said that there was a plug on the right side of the ten right wheel, and the bumper had a plug in the fender, and there was a contact with the electric master.
08.05.2020 17:47 # 3
yavuz_0051
I can look at it
08.05.2020 17:47 # 4
yavuz_0051
The problem is solved, there is a drier filter, it has changed. No problem. 130 TL
08.05.2020 17:47 # 5
mahmutbasaran
[QUOTE = yavuz_0051] problem solved there was dryer filter it changed no problem left 130 tl [/ QUOTE] voouuu a little too much for me ...
08.05.2020 17:47 # 6
yavuz_0051
80 pieces of 50 labor
08.05.2020 17:47 # 7
Aziz
get well, it came to me a lot, the dryer filter should be 40 tl of bits, does it change from vehicle to vehicle?
Anyway, let's not bother you, the past is gone, goodbye cool. Pöfür Pöfür.)
08.05.2020 17:47 # 8
206 ersan
[QUOTE = mahmutbasaran] [QUOTE = yavuz_0051] problem solved have a dryer filter it changed no problem 130 tl [/ QUOTE] voouuu a little too much for me ... [/ QUOTE] normally 62.5 TL is the most expensive pejo BMW 12.5 TL Mercedes 30 TL is the most expensive pejo and even 206
08.05.2020 17:47 # 9
mahmutbasaran
[QUOTE = 206 ersan] [QUOTE = mahmutbasaran] [QUOTE = yavuz_0051] problem solved there was dryer filter it changed no problem 130 tl [/ QUOTE] voouuu a little too much for me ... [/ QUOTE]
Normally 62.5 TL is the most expensive pejo BMW 12.5 TL Mercedes 30 TL is the most expensive pejo and even 206 [/ QUOTE] I guess the privilege of the lion.
