air conditioner replacement
08.05.2020 17:34 # 1
murattt
Hello all Peugeot users and master,
I have a little problem. The air conditioner is drilled, it does not work because there is no gas in the air conditioner.
I need to buy and replace the new air conditioner.
How do you write?
Tool: 307 sw
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; 2002 model 1.6 petrol.
Note: If there is a narration with photos or videos, it would be better, I searched on the internet, there is no tangible document about it.
regards
08.05.2020 17:34 # 2
murattt
Hello friends, I learned and changed how the radiator was changed as a result of my research.
First, I would like to share this with you.
First of all, we remove the water radiator for air conditioning radiator replacement. We remove the 4 clips on the front bumper, there are two screws on the right and left and we remove them.
2: On the bonnet opening button, we pull the bumper forward. . 4: When the radiator upper holders are removed, we remove the radiator hoses. (Put a large container underneath, the antifreeze flowing can be reused.)
5: The radiator discharging is removed upwards. There are two nuts at the bottom, holding the hoses, unscrew these nuts.
7: Carefully unscrew the hoses. Take care, especially since the bottom is thin, otherwise the tip may break inside.
8: Push the radiator towards the engine, pull it up and remove it.
9: Replace the retaining rubbers of the radiator. : Check the o-rings, replace them if missing or damaged.)
11: Replace the water radiator, connect the hoses, fill the water or antifreeze, remove the air
, complete the gap.
12: Top holders insert and screw.
13: Replace and screw the bumper into place and attach the clips.
Good luck ....
08.05.2020 17:34 # 3
SDYMZ
health teacher in your hands
08.05.2020 17:34 # 4
sezar206
Halal be good.
