AIR CONDITIONER INDICATOR PANEL REAR LIGHTING LIGHT FAILURE
08.05.2020 17:48 # 1
307imbenim
When I got in my car tonight, I realized that the air conditioner backlight was not lit, do you have any information? I am waiting for your help and your opinions, I would like to see your help and views.
08.05.2020 17:48 # 2
Eternal_Chaos
I had the same problem in mine, as I have given in the link below, I dismantled the console and got it done. But it's not easy, frankly. So it is necessary to be patient and careful. There are parts that can be broken. But if you are inclined, you do. If you say I can not, I think it is easy to install the lamps if you disassemble them to a master who is interested in car air conditioning. Good luck with...
http://forum.peugeotturkey.com/forum_posts.asp?tıd=6263&kw=klima+g%f6ster&title=206-scaklk-kontrol-paneli-aydnlatma-bakm
Now I realized, your vehicle was 307 :)
Removing the panel may be different, but the logic is the same. There are little bulbs they will change :)
There are friends who can help in detail about 307 ...
eternal_chaos 2013-07-17 04:22:09
08.05.2020 17:48 # 3
qqyyxx
Disassembling the heating panel of the 307 is quite difficult, it does more damage when I say that I do not go to any electrician who has not dismantled before. I recommend you to go to an authorized service and change it. I do not think that the bulb will be around 50 krş.
08.05.2020 17:48 # 4
307imbenim
I took it to an electrician today. I wanted to get 1 lira 30 lira. I bought the bulbs to get it out.
08.05.2020 17:48 # 5
Eternal_Chaos
If 307 is hard to disassemble and do it like a master man, give me 30 lira and don't think about it :)
08.05.2020 17:48 # 6
307imbenim
eywlh brother, it has never happened to you.
08.05.2020 17:48 # 7
307imbenim
actual
08.05.2020 17:48 # 8
rolandgarros
For 206 cars, I saved 1 TL with 3 bulb changes. Smile of course manual labor. it takes a little bit of effort. LOL
08.05.2020 17:48 # 9
307imbenim
If you knew how to remove your message after this hour, I would have contacted my brother.
08.05.2020 17:48 # 10
murateest
I removed the air conditioner part of 307, there is nothing to fear.
You can hardly remove the wires and wires behind the air conditioning unit even if you try.
I had dismantled the 2nd stage of the air conditioner because it did not work, but after I got it done, I installed it, but yesterday I realized that the lighting was not working.
No need to disassemble the top part.
When you remove the frame at the bottom, unscrew the 4 screws around the unit.
Rotate the unit by gently prying.
If I am not mistaken, it is not necessary to open the interior like 206, and the bulbs can come out behind us.
Today, tomorrow, I will take a detailed photo with my remover.
Do not disassemble it as it was written by friends who have not written before, because these works require experience, if there is no experience, a guide or a room or wow :)
08.05.2020 17:48 # 11
206FR
I changed the bulbs of the dashboard but it was easy :)
08.05.2020 17:48 # 12
murateest
I took it apart today, mine is quite simple, as I said.
If you just unscrew that part and poke it slightly, it turns slightly.
You will see 2 black lighting senses, you can remove it by turning it to any side.
