air conditioner does not cool
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 15:25 # 1
iibrahimm
Hi friends, I did not cool the air conditioner today, I used to cool it very little and it had a strange odor that it had previously been used. I did not see any gas given to the car air conditioner, I would be glad you helped
307 2004 1,4 hdi
08.05.2020 15:25 # 2
cerci07
As you said, the gas is over. The system is the same system. Give it to the refrigerator.
08.05.2020 15:25 # 3
iibrahimm
I don't know how accurate I heard they collected the old gas and cleaned the system, and the gas connection inlets are different with the refrigerator, maybe there is a different apparatus.
Is there any place you can recommend in Bursa
08.05.2020 15:25 # 4
Let the master work. He eats bread from this job ...
08.05.2020 15:26 # 5
mon
first they vacuum the old fluid in the system. It takes 15 to 20 minutes, then they print a134 r refrigerant. However, this system is a closed system why I think the fluid has decreased, first of all, if there is a leak in the system, it will be the same if you don't close it. See the bidet, let's see if the air conditioner motor turns while the air conditioner is on. if it doesn't turn, it probably doesn't have gas.
You take it to a master and tell me exactly, it was cooling last year, not this year, but you are looking for a leak in the system.
08.05.2020 15:26 # 6
Haksen016
On the five road in Bursa. Ist from Bursa. On the way to the right when I was on the way, if I think right, there was a air conditioner a little under the haystack food, I had gone before.
08.05.2020 15:26 # 7
[QUOTE = mon] first they vacuum the old fluid in the system. It takes 15 to 20 minutes, then they print a134 r refrigerant. However, this system is a closed system why I think the fluid has decreased, first of all, if there is a leak in the system, it will be the same if you don't close it. See the bidet, let's see if the air conditioner motor turns while the air conditioner is on. if it doesn't turn, it probably doesn't have gas.
I agree exactly Thumbs Up
08.05.2020 15:26 # 8
iibrahimm
the gas of the air conditioner was said to drop out in two or three years. Wall
08.05.2020 15:26 # 9
iibrahimm
I made the air conditioner, gas was reduced, there was 460 gr, 580 gr had to be collected, cleaned the gas, gave the gas again.
08.05.2020 15:26 # 10
307P
Has the problem been solved and does it cool anymore?
08.05.2020 15:26 # 11
ose
Let it cool down now Göz Kırpma
08.05.2020 15:26 # 12
If a closed system, such as it is called, gas is inexhaustible even in summer and summer, if it is properly insulated (see the law of conservation of mass), I am telling you because I am in the cooling business.
