air conditioner compressor
08.05.2020 19:24 # 1
fero.206
I had the hose of my car's air conditioner hollowed out. The gas was pressed. However, the air conditioner compressor is broken. Smile
08.05.2020 19:24 # 2
madblueblacksea
When I say broken.? When I open the air conditioner, it does not enter my circuit or it does not press the gas when it enters, it does not cool my air conditioner when it is pressed. Smile
08.05.2020 19:24 # 3
fero.206
By the way, the mechanic poured the gas back.
08.05.2020 19:24 # 4
madblueblacksea
Why it starts from the most expensive material and change could be the reason why it does not cool. I don't know if you were there when you tried the air conditioner, but the air conditioner compressor makes a loud noise when it comes in and out.
08.05.2020 19:24 # 5
fero.206
I do not think it would be wrong.
08.05.2020 19:24 # 6
madblueblacksea
I didn't mean the master was malicious. After all, he says whatever he understands, not the astrologer. Maybe there is a problem with the air conditioner controls, it does not direct the cold air flow. First of all, evaluate the costless possibilities, I think the last thing you do should be a compressor. If there is a compressor he can test in his hand and confirm
08.05.2020 19:24 # 7
fero.206
You're the right one.
08.05.2020 19:24 # 8
BZC
I recommend you go to a few more masters. He said that I went to his restaurant, he said it will change, the other said it would be repaired. Finally, a master changed the valve for 6 months without any problem.
Cost: 20 TL (valve) + 60 TL (gas) = 80 TL
BZC 2015-08-14 13:44:21
08.05.2020 19:24 # 9
fero.206
Let me die like that too.
08.05.2020 19:24 # 10
Faruk
my 307's changed 2 years ago.
bounces were 500 tl or something.
As a malfunction, when the air conditioner was turned on, it sounded like a click, the vehicle's traction was falling but it was not blowing cold.
it changed when it changed.
