air conditioner ball
08.05.2020 14:15 # 1
erol
There is a sound called gırç gırç from the vehicle. This is the reason the service tells me. Is there anybody living this situation, can I change the air conditioner ball outside? Is there any master you know around Izmit? let's 2010-05-25 00:34:44
08.05.2020 14:15 # 2
oguzhan29
I am in Gümüşhane, I changed this ball to the master I knew from here. I found it here. You can find a master there and do some research.
08.05.2020 14:15 # 3
bbcb
I changed the air-conditioning ball before, let me tell you, the ball is broken, I am not aware that when changing the tiriger set, the master said it was broken, but if there wasn't any bison, he said that the master said to me, when I turned on and off the ball-bearing, there was no sound, as I said, I would have switched on it.
08.05.2020 14:15 # 4
okankrgz
I had a problem when I had 106 quick, but the sound was cut after opening and lubricating a sound caused by the engine that blows the air to the combs. I had to understand exactly how there was a problem in your vehicle. Where are you in Izmit, I am in Izmit.
08.05.2020 14:16 # 5
Psh
I have Kartepe denim.
