air conditioner and heater are not working please help
08.05.2020 14:57 # 1
gurcan42
Hello friends, I just joined you. I bought HDI for about 1 month. But today I saw that the heating air flow was not working. It was not working in the same way before.
08.05.2020 14:57 # 2
BAHTIYAR
There is a plastic part on the left side of the steering wheel 206, the fuses are there, probably the resinstat may be burned. I don't know much about this
08.05.2020 14:57 # 3
narkotik71
my car is automatic digital air conditioned. There is no problem in the summer months. But is it necessary to turn on the air conditioner to run warm in winter or do we have a location where we can get the engine temperature. 307 2003.
08.05.2020 14:57 # 4
narkotik71
Gürcan, easy to come to you, the fuses have been replaced by friends. After starting the car, there is a replacement fuse in the ac motor sound. Make sure that the lids are open inside. The air conditioner gas may be over.
08.05.2020 14:57 # 5
sdaldal
Does my insurance stems from the same problem in me, but the place of insurance is not visible in his book ...
08.05.2020 14:57 # 6
serkan24577
the same problem was in me before, lonely, hot, cold, blown, air, the gas hose of the air conditioner was pierced so it did not open the air conditioner
08.05.2020 14:57 # 7
[QUOTE=gürcan42]arkadaşlar merhaba bende aranıza yeni katıldım .206 HDİ aldım yaklaşık 1 ay oldu.Ancak bugün kalorifer hava debisnin çalışmadığını gördüm önceden çalışıyordu aynı şekilde klimada çalışmıyor.zannediyorum sigortası attı ama sigortasını bulamadım .Sigorta ve kalorifer elektrik tesisatı ile ilgili bigilendirecek arkadaş olursa sevinirim.Teşekkürler.
[/QUOTE]
Asagidaki tablo isinizi fazlasiyla gorecektir. Kontrol etmeniz gereken, F1 (10 Amperlik, AC kompresoru), F18 (30 Amper, AC Fani). Kaynakta belirtildigine gore bu sigortalar kaputun altindaki yerde. Kolay gelsin.
Application chart for PEUGEOT 206 from DAM 9062, multiplexed.
BSI fuses near steering column
Fuses in BSI
Fuse
Rating
Function
F1
15 A
Heated seat
F4
20 A
Light for: Multifunction screen, navigation, boot.
F5
15 A
Automatic transmission diagnostics.
F6
10 A
Coolant level, automatic transmission.
F7
15 A
Driving school ECU, alarm ECU.
F9
30 A
Rear electric window
F10
40 A
Rear screen and mirrors demisting.
F11
15 A
Rear wiper.
F12
30 A
Electric front windows, sun roof.
F14
10 A
Engine wiring housing, COM 2000
F15
15 A
Instruments, multifunction screen, climate control, radio.
F16
30 A
Openings, locking, deadlocking control.
F20
10 A
Right brake light.
F21
15 A
Left brake light, additional brake light.
F22
30 A
Front courtesy light, front map reading light, lighter.
FS1
Shunt
BF34
Fuse box under bonnet BM34
Fuse
Rating
Function
F1
10 A
Reversing lamps, injection double relay, engine oil temp, fluid level, AC compressor
F2
15 A
Fuel pump, canister solenoid valve.
F3
10 A
ABS ECU.
F4
10 A
Engine ECU and automatic transmission.
F5
F6
F7
20 A
Headlamp wash.
F8
20 A
Direct injection ECU, injection ECU command relay, injection ECU.
F9
15 A
Left dipped beam.
F10
15 A
Right dipped beam.
F11
10 A
Left high beam.
F12
10 A
Right high beam.
F13
15 A
Horn
F14
10 A
Front and rear screen wash pump.
F15
30 A
Ignition coil, screen wiper, O² sensor, oil pressure, injection
F16
30 A
Air pump relay.
F17
30 A
Front wipers low and high speed.
F18
30 A
AC blower motor, starter.
Maxi fuse BM34
Fuse
Rating
Function
F1
20 A
Fan
F2
60 A
ABS
F3
30 A
ABS
F4
70 A
Feed to BSI
F5
70 A
Feed to BSI
F6
F7
30 A
Anty theft contact power supply
F8
Kaynak: http://www.peugeotlogic.com
koliva2011-02-06 12:24:48
