air conditioner and heater are not working
08.05.2020 14:57 # 1
gurcan42
The heater and air conditioner of my 206 HDI vehicle do not work.
08.05.2020 14:57 # 2
sdaldal
Have you solved your problem? There are 307 in me, it has stopped working. Can you help if you solved the problem?
08.05.2020 14:57 # 3
Muhammet CAKIR
the cable of the fan motor may also be disconnected.
08.05.2020 14:57 # 4
[QUOTE=gürcan42]206 HDİ aracımın kalorifer ve kliması çalışmıyor.Zannedersem elektrikle ilgili bir sorunu var.Hava debisini açtığımda hiç üfleme yapmıyor.motoru hiç çalışmıyor.İçerideki sigorta panosuna baktım ama tüm sigortalar sağlam gözüküyor.Acaba klima ve kalorifer sigortası başka bir yerde olabilir mi.[/QUOTE]
Asagidaki tablo isinizi fazlasiyla gorecektir. Kontrol etmeniz gereken, F1 (10 Amperlik, AC kompresoru), F18 (30 Amper, AC Fani). Kaynakta belirtildigine gore bu sigortalar kaputun altindaki yerde. Kolay gelsin.
Application chart for PEUGEOT 206 from DAM 9062, multiplexed.
BSI fuses near steering column
Fuses in BSI
Fuse
Rating
Function
F1
15 A
Heated seat
F4
20 A
Light for: Multifunction screen, navigation, boot.
F5
15 A
Automatic transmission diagnostics.
F6
10 A
Coolant level, automatic transmission.
F7
15 A
Driving school ECU, alarm ECU.
F9
30 A
Rear electric window
F10
40 A
Rear screen and mirrors demisting.
F11
15 A
Rear wiper.
F12
30 A
Electric front windows, sun roof.
F14
10 A
Engine wiring housing, COM 2000
F15
15 A
Instruments, multifunction screen, climate control, radio.
F16
30 A
Openings, locking, deadlocking control.
F20
10 A
Right brake light.
F21
15 A
Left brake light, additional brake light.
F22
30 A
Front courtesy light, front map reading light, lighter.
FS1
Shunt
BF34
Fuse box under bonnet BM34
Fuse
Rating
Function
F1
10 A
Reversing lamps, injection double relay, engine oil temp, fluid level, AC compressor
F2
15 A
Fuel pump, canister solenoid valve.
F3
10 A
ABS ECU.
F4
10 A
Engine ECU and automatic transmission.
F5
F6
F7
20 A
Headlamp wash.
F8
20 A
Direct injection ECU, injection ECU command relay, injection ECU.
F9
15 A
Left dipped beam.
F10
15 A
Right dipped beam.
F11
10 A
Left high beam.
F12
10 A
Right high beam.
F13
15 A
Horn
F14
10 A
Front and rear screen wash pump.
F15
30 A
Ignition coil, screen wiper, O² sensor, oil pressure, injection
F16
30 A
Air pump relay.
F17
30 A
Front wipers low and high speed.
F18
30 A
AC blower motor, starter.
Maxi fuse BM34
Fuse
Rating
Function
F1
20 A
Fan
F2
60 A
ABS
F3
30 A
ABS
F4
70 A
Feed to BSI
F5
70 A
Feed to BSI
F6
F7
30 A
Anty theft contact power supply
F8
Kaynak: http://www.peugeotlogic.com
