Air Conditioner Air Outlet Change
08.05.2020 19:09 # 1
blntctn
Friends air conditioner air outlet is broken in me, so when I take the places I marked in the picture to the left and right, 1 of them can only move, the others are out of the socket, I do not understand if they are broken, how can I repair them, how can I insert a new one or if it is cheap?
08.05.2020 19:09 # 2
GokhaN
Remove the ventilation plastics from the edges with a flat screwdriver from the large sections with the blades, they are passing.
After removing, fix the ducts again. Unbreakable, easy, easy
08.05.2020 19:09 # 3
blntctn
[QUOTE = GökhaN] remove the ventilation plastics from the edges with a flat screwdriver from the wide sections where the knocking keys are, they are passed.
Thanks, it will be my first job in the evening :)
08.05.2020 19:09 # 4
GokhaN
[QUOTE = blntctn] [QUOTE = GökhaN] remove the ventilation plastics from the edges with a flat screwdriver from the large sections where the knobs are, they are passed.
Wink you are welcome you can do it simple
