Air Conditioner Advice in Istanbul
08.05.2020 20:25 # 1
voleano
Hello friends,
My vehicle 307 1.6 HDI 2006 model vanity case. When I operated the air conditioner at the highest level last year, there were small splashes of water from the honeycombs. At the same time, there was a water flow in the foot part of the driver and passenger sides. Now, on the right side of the air conditioner, there is a cold blowing on the left side. Though the gas is over now, I think it comes completely hot. How much will it cost? I asked a few places, they said different answers and prices. I'm confused and I'm afraid of getting ripped off, frankly. Are there any masters that we can trust and recommend that understand this job well? I ask for help from friends who know. Tşkler.
08.05.2020 20:25 # 2
Popomundo
Topkapı da Işın auto electric air conditioning service will help if you say that you have a murat master from the forum 0212 482 39 66 popomundo 2017-06-19 03:01:32
08.05.2020 20:25 # 3
voleano
I went to Murat Usta. There was no problem when the gas filled the air conditioner. Thank you.
Thank you too.
08.05.2020 20:25 # 4
sdttn
Air conditioning gas is not a waste like gasoline, wiper water. If there is a leak in your system, if this leak is not repaired, your gas will run out again in a short time.
08.05.2020 20:25 # 5
ben_erhan
If my brother air conditioner is turned on, if water comes from the honeycombs, the air conditioner drain is blocked.
It happened to me .. I lifted the car on the fiber, there was a drain pipe at the bottom and there was rubbish and dirt filled before and the mats were getting wet ... 5tl. The problem they got was solved ..
08.05.2020 20:25 # 6
doganatak
[QUOTE = voleano] I went to Murat Usta. There was no problem when the gas filled the air conditioner. Thank you.
Thank you too.
how much did you fill in the air conditioning gas, I will go out on Saturday after work, let me know about the price very close to my workplace
08.05.2020 20:25 # 7
whisky
[QUOTE = doganatak] [QUOTE = voleano] I went to Murat Usta. There was no problem when the gas filled the air conditioner. Thank you.
Thank you too.
[/ QUOTE] They say around 80-100 pounds where I am in the industry, but it may be more convenient or more. it's not too expensive.
08.05.2020 20:25 # 8
doganatak
Today, Işın went to the auto, gasped, sent me the air conditioner is working now. He was the authorized dealer of cenmax alarm. Cry we couldn't get an alarm again. I also said change the pollen filter, do you think I should get the original is there a difference. Maybe I need to write the Murat master's mobile number. 0535 564 41 23 location is not complicated, by the way, gas filling is 100 TL
08.05.2020 20:25 # 9
madblueblacksea
I definitely recommend you to buy the pollen filter as original. There is a difference of 5 lira between them, but the side industry is not fully seated, the sides remain open, collapses, escapes nothing
