Air conditioner 2 radiators hot issue
10.08.2023 00:53 # 1
mahmut alpay
Hello, the 4 grilles in the front are blowing hot on both right sides and cold on both left sides. It was said that there was a lack of gas, but the problem was fixed temporarily. They said the compressor was weak and needed to be replaced along with the honeycomb. Someone else had the same problem. There is an adjustment at the bottom, and when I replaced it, it was fixed. How can I understand if the compressor is weak? This situation is like this. Hot blowing from both sides and cold blowing from both left sides. Have you experienced this before? Do you have any suggestions for how to fix the problem if it happens again? What is it? I will need to find a uata. Do you have any suggestions?
