Air Condition Panel Light Problem
08.05.2020 19:07 # 1
Emrhn
Half of the Lights of the A / C Panel Are On
Can I change it myself, can you help me?
08.05.2020 19:07 # 2
KuzuX
You change very easily.
08.05.2020 19:07 # 3
Emrhn
I disassembled the air conditioner panel before. There was no light bulb behind him, there was only a socket, and I put it back.
08.05.2020 19:07 # 4
yusuf_18
You pull the info screen up and out. Then you see two screws there, you open them too. If you remove the tape at the bottom, there are two fingernails at the bottom of the air conditioner panel. You pull the center console lightly. Then you will see the bulb sockets, like three screws, behind the panel. The ones on the right and left are lower in the middle, in the upper part. You flip it out. There are bottomless indicator bulbs in them. It is thinner than normal bottomless bulbs. You take off the bang and put on a new one. The price is 50 kurus each.
08.05.2020 19:07 # 5
Emrhn
there is nothing like a sensation behind the panel
08.05.2020 19:07 # 6
suppor
There are 3 bottomless bulbs, but if it is inserted, you can remove the air duct, then remove the screw from the nail, then remove it from the nails after removing it.
I had some summer sweat when I was stuck.
08.05.2020 19:07 # 7
yusuf_18
Something plastic, like screw. How I describe it looks like its cover. Outwardly protruding. When they disassemble the center console and check the back of the panel with your hand, they come to your hand. But there is no need to open the inside of the panel. As the suppor says, the information display is the same. If you look behind the information screen, you will see what it is looking for. Wink
08.05.2020 19:07 # 8
okaNStarss
Remove the panel, pull the wires without breaking the wires with the help of the pliers from the back, open the panwli screws but do not forget the locations of the buttons in front of them.
08.05.2020 19:07 # 9
riderzist
it is very simple to change it, you get the t5 bottomless bulb, i took 2 kinds of it from the thin one like a parking bulb and the t5 bottomless bulb panel removal as thin as a quarter of it is on the forum.
08.05.2020 19:07 # 10
Emrhn
Thank you for the information you provided, I will remove it again today
How can I put the license plate lamps into white fog and zenon
I just bought the tool crafting is really hard
