Air bag
08.05.2020 14:14 # 1
cankurts
Hello Friends, the driver was worn on the airbag, I said I'll change it, how can I remove it?
08.05.2020 14:14 # 2
t@lip
If you look at the "how-to" section, there was a very detailed recipe, thanks to Haşim Bey for 206.
08.05.2020 14:14 # 3
deamod
If you think you can aspire to what you will do, please contact us privately.
08.05.2020 14:14 # 4
I had read somewhere. The use of airbags is 10 years. Well, after the 10-year life, the airbags need to be replaced even if they are intact. Do you have any knowledge about this topic?
08.05.2020 14:14 # 5
[QUOTE = badires] I read somewhere. The use of airbags is 10 years. Well, after the 10-year life, the airbags need to be replaced even if they are intact. Do you know about this? [/ QUOTE]
It is true for 10 years, but after 10 years, it will not cause any problems when necessary checks are made. The last time Volvo took this time for 15 years, maybe it was all, but the known time is 10 years.
Koliva 2011-06-20 10:19:23
08.05.2020 14:14 # 6
So what are these "necessary controls"? To whom, how and how much?
08.05.2020 14:14 # 7
Corrosion occurs over time in the vehicle's SRS connections. As far as I know, only these points are overlooked. The rest can already be controlled with diagonastic instruments. The answer to the "To" question is probably an authorized service. Göz Kırpma
Koliva 2011-06-20 10:43:59
08.05.2020 14:14 # 8
Got it, Master. I can not get rid of that authorized service.
