AID, WARNING SOUNDS, OIL LAMP, STOP LAMP SIDE
08.05.2020 19:53 # 1
caresiz
I RECEIVED MY VEHICLE, PEJO 2307 XR. THE WARNING SOUND IN MY VEHICLE DOES WITH 3 TIMES, IN THE SAME TIME WITH THE OIL LAMP VEW STOP LAMP.
08.05.2020 19:53 # 2
firstly welcome. I would be glad if you introduce yourself from the member promotion section. When it comes to the problem, I gave the error code to my computer. I also give the same problem in turn off the LPG system of your vehicle. I think a throttle clean coil check and replace spark plugs. and get a good lpg setting.
08.05.2020 19:53 # 3
caresiz
mrb, abdullah ben. no error code, they put it in the compit no problem. but it is also doing lpg.
08.05.2020 19:53 # 4
As I said, Abdullah clear the throttle and get a calibration. There is a birdelpg map sensor. Have it checked. I think the lpg adjustment of the vehicle is done properly, I think there is no problem.
08.05.2020 19:53 # 5
lamazibici06
I look at air filters and throttle
