Age & Condition of Vehicle Tires
08.05.2020 15:21 # 1
Vehicle tires, date of manufacture
5 years
it is recommended not to be used later.
Because they will lose their elasticity,
tire that expires
as it will decrease to the ground,
due to cracking
(especially in hot seasons)
during use
risk of explosion
It bears.
How do you know the production dates of your tires?
There is a stamp on the tires (4002).
The first two numbers on this stamp indicate the week the tire was produced, and the last two numbers indicate the year.
The stamp 4002 in the example indicates that the tire was produced in the 40th week of 2002.
In another example (2699) states that the tire was produced in the 26th week of 1999.
Check the vehicle tires for your safety.
Do not use tires that have reached the end of their life.
the albaydemirc 2011-04-28 00:49:14
08.05.2020 15:21 # 2
motoberk
I know the shelf life is 5 years, but I may be wrong.
08.05.2020 15:21 # 3
Whether the shelf does not matter. the result is 5 years :))
After 5 years, attitude starts to weaken and suddenly the risk of explosion increases with the catings as mentioned above.
Otherwise, it goes on a 10-year-old tire, but it may explode at an unexpected time or may not hold you at a point where you would like to hold it, but may dispatch you to an accident.
At this point, it is not enough just to look at the tire's history ...
When burning, we should not sneak to the sidewalks
we should not fall into hard pits
we shouldn't leave the tire in the rain
we shouldn't take the sidewalk up and leave it halfway
We should not do the ramp-down or full-right with the uphill, leaning the tire on the pavement and crushing it.
Of course we have to check the weather periodically
08.05.2020 15:21 # 4
Haksen016
thanks for sharing.
08.05.2020 15:21 # 5
metin
5 years if you use it alone for 5 years. that is, we should not use it for 5 years after 5 years of shelf life. It is vital to renew the most beautiful tires.
For example, the tread depth of my tires was very good, but it was produced in 2006 and cracks started to occur on me. I changed it, now I am comfortable.
08.05.2020 15:21 # 6
thank you useful sharing.
08.05.2020 15:21 # 7
I thank you all for evaluating the subject I wrote
08.05.2020 15:21 # 8
Colonel, thank you for enriching us with such information :)) selametlee
08.05.2020 15:21 # 9
harmus
Arkadaşlar, bir siteden aldığım ve lastikler hakkında güzel bir çalışmayı aktarmak isterim.
Lastik kullanırken dikkat etmemiz gereken unsurlar::
1-) Lastikler arabanın giderken en önemli noktasıdır.çünkü bütün
yoltutuş lastiklere bağlıdır.mümkün olduğunca aracımıza orjinal ölçüler
de lastik takmalıyız.Aracın lastiklerinin normalden kalın olması en
başta yakıt tüketiminin artmasına yol açar.direksiyon sertleşir. rot ve
rot başlarını zorlar.baskı balatayı yer amartisörlere zarar verir vs vs..ama mesela yoltutuşu zayıf olan araçta 155 lastik yerine 165 lastik takılabilir. ama tutupta 195 lastik takmak aracı yorar.performans kaybı olur.
2-)lastik alırken marka çok önemli.şu marka iyi yada kötü demeyecem
ancak lastik alırken mutlaka üretim tarihini sorun!!!!! lastiğinde
üretim tarihi olurmuymuş demeyin. genelde çerçeve içine alınmış
4haneli sayıdan oluşur.genelde küçüktür.bazı üreticiler bunu yazmazlar.
çünkü elde kalan lastiği satmak isterler.ve bunlar ucuzdur.ama lastikçiler
yeni üretilmiş lastikle aynı paraya satarlar.üretim tarihinde ay hafta pek
önemli değildir.işin özü üretim SENESİDİR.mesela sıfır lastik alacaksınız.
üretim tarihi 2000 olan lastiği ALMAYIN!!!! niyemi? çünkü lastiğin
kavuçuğu zamanla kullanılmasa hatta poşetinde olsa bile sertleşir!!!
yol tutuş hissedilir derecede azalır.mümkün olduğunca 2004 senesinden
önce üretilmiş lastikleri almayın!!!! 4 haneli sayıdan bahsettim.
genelde(michelin ve yokohama toyo bf goodrich gibi markalarda yazıyor)
çerçeve içine alınmış 4haneli sayının açılımını yapalım.
örneğin 2305 yazıyorsa bu son iki sayıdan yola çıkarak yani 05
2005de üretildiğini anlıyoruz.ilk 2 rakam olan 23 ise lastiğin üretildiği
haftayı belirtir. yani lastik 2005 in 23. haftasında üretilmiştir.
örneğin 0304 yazıyorsa 2004 ün 3.haftası üretilmiştir.
(ekbilgi) lastik ölçüsü ise şöyle yorumlanır:
175/65R 14H burada
175 taban kalınlığı mm olark
65 taban kalınlığının yanağa oranı(bu genelde yanlış bilinir doğrusu
budur.mm yada cm falan değildir)
R lastiğin radyal yani iç lastiksiz olduğunu belirtir
14 jantın boyu inc olarak
H hız gurubudur. H lastiğin max 210km ye kadar dayanabildiğini belirtir
T ise 190 km hıza kadar kullanıldığını belirtir. V ise 240a kadar vs vs
3-) burdan şu sonucu çıkarırız. arabanızın maksimum hızına duyarlı
olup sizin aracınıza uygun hız grubuna uyan lastiği alın.
mesela benim aracımın max hızı katalog verisi 190km ancak babam
lastiği değiştirirken T grubu lastik vermişler. yani max 190 olan.
ancak aracın orjinalinde H vardı.bu durum pek önemsenmez. yokuş aşağı
durumlarda 190km yi rahat 190 geçileceğinden (ben 210 yaptım h lastikle) bu tehlikeli durum arz eder.dikkat etmeniz gereken başka nokta...
ayrıca T ve H (yani yakın hız grupları) yapı gereği tamamen farklıdır.
H grubu lastikler daha iyi yol tutar.burdan şu anlaşılmasın. aracın orjinali
T ise H yapmak çok aşırı etkilemez.ama mümkün olduğunca dikkat edin,düşük hız grubu lastik almayın...
4-) yuvarlanma direnci az olan yani energy lastikleri tercih edin. bu yakıt tüketimini biraz olsun azaltabilir.
5-) aracınızın lasiğinin değişmesini şu şekilde anlarız:
lastik diş derinliği 1.6mm nin altına düşerse
lastiğiniz 3yılı doldurmuşsa
yada aracınız 40000km nin üstünde yol yapmışsa
lastik derinliğini cetvelle falan ölçmenize gerek yok.lastik dişlerinin
içinde bir çizgi vardır.bu çizgi ile (buda bir diştir) lastik dişiniz eşit
seviyeye gelince lastik ömrünü tamamlamıştır.(ayrıca yasal zorunluluk)
burdan sonra lastiğiniz yavaş yavaş kabak olarak tabir edilen lastiğe dönüşür
yol tutuş bariz şekilde azalır.hayati tehlike başlar...
bunu kimse bilmez. aracımıza yeni lastik aldık.4 yılda 10000 km yol yaptık.
doğal olarak lastik dişi daha yerindedir. AMA LASTİK ARTIK ESKİMİŞTİR.
lastiğin eskimesi için kullanmaya gerek yoktur.bu genelde BİLİNMEZ.
biz dişleri az eskimiş olan 6senelik lastiklerle kuru havada gereğinden
fazla kayarak büyük 1 kaza yaptıkKaşlarını Çatmak lütfen bu lastik üretim tarihi ile
lastiğin dişi olmasına rağmen kağuçuğunun ölmesi olayına önem verelim.
lastiğin kağuçuğunun öldüğünü en basit şekilde nasıl anlarız? lastikte
kılcal çatlaklar başlamışsa SÜPERRRRRRR ACİİİİİİİİİL lastiği çöpe
atın!!!!!!! yüzlerce kez ve yüzlerce kişiye bunu ispatladım.araç üzerinde eski lastiklerle (lastik dişi sağlam gözüken) fren yaptığımda araç aptallaşarak kaymaya başlıyor. ama aynı gün aynı yerde yeni lastiklerle sonuç:MÜKEMMMMMMELGülmek
lütfen bu 5. maddeyi yabana atmayın derim,kendi canınızı taşıyorsunuz...
40.000 km nin üzerindeki lastikleri en kısa sürede değiştirin derim.yada kontrol ettirip öyle binin.
6-) rot balans ayarlarını en geç 5000 lüx arabalar için en geç 10.000 km de bir yaptırın. düzensiz rot balans ayarları lastiğin aşınmasını arttırır.titreme yapar.
7-) lastiğiniz tabandan patlamışsa muhakkak soğuk kaynak yaptırın. ve yapıldıktan hemen sonra balans ayarına sokun(mümkünse 4ünü birden)
8-) lastiğiniz yanaktan patlamış/yırtılmışsa o lastik direk çöpeeeeeeeeee
9-) ülkemiz yolları malum. lastik yanağını düşük taktırırsak latiğin yere basan kısmıyla jant arası mesafe kısalacağından çukurlarda lastik yanağında fındık denilen şişmeler meydana gelir.yüksek süratlerde aracın lastik dönüşü düzensizleşir. fındık yapmış lastiklerle uzun yola kesinlikle çıkmayın.fındık yapan yer yırılabilir.ama şehir içinde dikkatli olun.
10-) lastik havaları çok önemlidir.katolog verisi olan basıncı lastiklere uygulayın.
araçta extra ağırlık varsa 2psi basıncı arttırın. karlı havalarda lastiğin havasını 2psi arttırın!!! sanılanın aksine lastik havasını düşürmek değil arttırmak lazım.
11-) bulunduğunuz şehirde kar fazlaysa mutlaka kar lastiği alın!!! yol tutşa büyük katkısı var
12-) aracınıza binerken 4lastiğe göz kararı bakın, bu 10 saniyenizi almaz.patlak ve inik lastikle yola çıkmak sakıncalıdır ve araç yol tutuşunu bariz bozar...
13-) araç park ederken kaldırımlar lastiğin DÜŞMANIDIR. park ederken lastiği kaldırıma çarptırmayın.
bu aşırı zararlıdır. birde lastiği taşın vs. değişik yüksek yere de çıkarıp üzerinde bırakmayın.
buda zararlıdır.
14-) jantınızın yamuk olup olmadığını kontrol ettirin. yamuk jantı 2 sefer düzelttirmişseniz
jant bu sefer hamurlaşıp yumuşayacağından artık daha kolay yamulur. dikkatli olun ve değiştirin.
15-) lastiğinize basınçlı suyu ASLA ve ASLA KESİNLİKLE T-U-T-M-A-Y-I-N!!!!! (!) araba dergisinde birebir gördüm lastiğe tutulan basınçlı su lastiği gözle görülmese bile parçalıyor!!! sık sık tutarsanız lastiğinizden parçalar koptuğunu göreceksiniz ve bu çok ZARARLIDIR. ayrıca lastiğinizi şampuan deterjan köpüklü
ürünlerle değil saf su ile temizleyin!!! parlamıyo diyorsanız özel satılan ürünler alın. Köük deterjan vs lastiğin kimyasalını bozar!!!!!!!!!!!!! tehlike oluşturur Allah korusun...
16-) aracı patinaja bırakmayın,lastiğe zarar verdiği gibi lastikten parça kopmasına neden olur. aynı şey fren için de geçerlidir. çok uzun ani fren yapmak lastiğin kayan kısmıyla diğer kısımları arasında diş kalınlığı farkı yaratacağından lastiğin giderken titremesine neden olur(rot balans la ilgisi yok!!!!!!!!!!!!!!!!!!!!!!!!!!!)
17-) paranız varsa/yeterse mümkün olduğu kadar tanınmış markaları tercih edin,büyük firmalar ciddi para ayırıyorlar benden söylemesi... (ama dayanıklılık konusunda bütün firmalar bence bekleneni fazlasıya veriyor bence)
18-lastiğin sipop kapağını kapalı tutalım.içine pislik kaçarsa hava basılmıyor...
19 her lastik değiştiğinde sibopları değiştirtin!!!!!
20-) lastik patlak değilse ama hava kaçırıyorsa ve eskiyse doğru çöpeeeeeeeeee:ka05: yeniyse garantiye verin...
Arkadaşlar yine aklıma gelen bunlar şimdilik,yine gelirse buraya yazarım!!!!
kesinlikle alıntı DEĞİLDİR.
LÜTFEN LASTİĞİ ÖNEMSEYELİM!!!! LASTİK ARCIMIZIN YERE BASAN 4 HAYATİ ÖNEMDE PARÇASIDIR.
AlbayDemircan2011-05-12 13:47:26
08.05.2020 15:21 # 10
yeditepely
I revived the subject, but this is a very necessary information. Thank you for sharing.
08.05.2020 15:21 # 11
muurrat
Thank you very useful information
08.05.2020 15:21 # 12
Engin Tepe
Yes, every time we wash our tires, we keep the tires with water. Do you have any place in that tanzigli water body? Argh
08.05.2020 15:21 # 13
A useful and important share of labor
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
