again the new knock problem 307
08.05.2020 17:02 # 1
salihata
friends I have a question about the chronic problem of the peugeot 307 with automatic transmission, I searched the forum and there is a mess about this problem, there is no problem when it is connected to the computer, there is no warning lamp but the vehicles get up with a hard knock when getting up and a lot of written transmission oil There are those who say that they should change, those who say that the bushings should be changed, those who say that the brake cue should change, those who say that the selonoid valves should change, there are also those who say change the throat butterfly, that is, there are friends who try them in order, the men are spending 2 thousand liras and 3 thousand liras and still their problems continue, and some of them still have problems. is increasing, is there no clear answer to this question? Is there any experienced friend who will say that the vehicle will be fixed if you change it here because of this?
08.05.2020 17:02 # 2
fexzi
I have the same problem when it reaches 90 degrees but it's not overly exaggerated, my diagnosis as someone who changes the gearbox oil every 20 thousand is chronic discomfort in the 307 AL4 gearbox. div>
As you said, when I put it into service in Ankara and Konya, there is no problem, when I connect to the computer, the problem persists occasionally, although I am meticulous, I use it triptonically when it exceeds 90 degrees.
08.05.2020 17:02 # 3
foresteng.
I have 206 too. I used this holiday manually; both fuel consumption and gear shifts are more comfortable and painless .. I used it in D position only when I was getting up and in congested traffic.
08.05.2020 17:02 # 4
berk2309
my teacher, you can not fix it, I have 307 of the new safes in my friend. The small heat exchanger used for the n & nbsp; you can use the bole in the summer to ensure that it cools the cold thermostat & nbsp; it does not cause any trouble.
08.05.2020 17:02 # 5
salihata
[QUOTE = berk2309] you can't fix my teacher empty, I hit my friend in 307 of the new crates & nbsp; when it gets too hot, I hit it as a blunt & nbsp; I did not take care of my friend, I did not hurt, I did not last any longer. & nbsp; I think the heat exchanger used to cool the oil stays small & nbsp; it gives you the chance to cool it down and it does not cause any trouble to use bole in the summer to make sure it cools down. Using it this way is a problem, when this event is on a slope, the car backs up or when you get up on a normal straight road, you will be entering the vehicle in front, & nbsp;
08.05.2020 17:02 # 6
berk2309
Exactly like that, but my teacher, I don't have a solution, no matter what you try. I think you did not hit it too much, even though & nbsp; the perfect thing like & nbsp; of course, when the traffic stops, it turns up again when the heat faded, the heat fell back when it cooled.
08.05.2020 17:02 # 7
berk2309
even this heat, my car had the old case radiator, I replaced it with the big radiator in the new medical cases, it didn't change again: D & nbsp;
08.05.2020 17:02 # 8
salihata
If I continue to use the tool with this problem now, won't it cause me any trouble? I am afraid that it will cause bigger transmission problems in the future. Obviously, when the vehicle takes itself into the void, I am forced to get it in triptonic gear to get back to 2 so that the vehicle cannot escape.
08.05.2020 17:02 # 9
berk2309
I can not tell you that yours is a very normal thing.
08.05.2020 17:02 # 10
salihata
[QUOTE = berk2309] I can not tell you that your cousin is very normal, I think, if you take it to the bosom, then you see it & nbsp; look at it, there are a few more people who have experienced it. when it is as if everything is silent, the engine stops, it is as if calm is not working at all whatever when i press the gas, the pat gets up with a noisy knock but if i stay in the 2nd gear, such a knock does not happen. In the searches, the solenoid, the brake custom, the bushings and so on, now the radiator, so if I change them one by one, the trial will be a lot of money because of the error, I say that one of my dear brother, this is definitely a change from solenoids, but there is no such information & nbsp; whatever the problem is, the automatic transmission does not solve the problem, it says solenoid, it changes it continues. >
08.05.2020 17:02 # 11
volkan22
If you ask me, this problem was going to hit me in my transmission, my bva al4 car 306 & nbsp; it was knocked on me sometimes, even when the slope came out, snow and sports light shifted to 3rd gear problem, I think the oil is warming up, but I think that the oil change does not cost much, I think the chance is as soon as I say ole do not ask the service from the pouring service & nbsp; & nbsp;
meanwhile, I said it is going to knock, or the upper engine wedge will make it cut off from the bottom, the wurunt will decrease & nbsp; the opposite of me is not in 1st gear, only 2 gears or little knocking when night passes & nbsp; Here, every day when I take the mountain road, the wilt is at the same point as the hill is coming out. When I get into the second gear, I press it in a little more.
walla I think you can do anything if the oil is changing, but try the chance of cheap road. Give gas, look, does the engine shake?
08.05.2020 17:02 # 12
salihata
[QUOTE = volkan22] If you ask me, this war was going to be a problem in my transmission, my car was beating my car 306 & nbsp; it was killing me sometimes, even when the slope came out, snow and sports light was shifting to the third gear. I say good luck and I think they will ask the service from oil service as soon as possible. & nbsp; & nbsp;
meanwhile, I said it is going to knock, or the upper engine wedge will make it cut off from the bottom, the wurunt will decrease & nbsp; In my case the opposite is not in 1st gear, only 2 gears are knocked down while passing or going down. & nbsp; When I went to change the gearbox oil, the master told me that these oils were lifetime, and the answer to my mind about this knock was the engine mount. and the transmission bushings have an idea about the cost of these two?
08.05.2020 17:02 # 13
berk2309
If your oil is too hot, look at your heat exchanger, and if you think it is due to the heat of the oil & nbsp;
08.05.2020 17:02 # 14
volkan22
I am on the way & nbsp; when I get out of the Bosphorus, the car always burns sports snow lights. The temperature is at 90 & nbsp;
I am fast & nbsp; I'm leaving & nbsp; yokus & nbsp; and it is the same thing when the car does not hit the normal road at the same point every day. cu shifting from second gear to a serious knock while falling into second gear & nbsp; the vehicle's pulling is perfect I think the problem is just like your friend is like war.
Remove the pipes from the radiator, from the auto transmission.
why did the factory put it? So it shouldn't be heated. In addition, the water coming out of the radiator can be cooled in the transmission, maybe enough of time may become obstructed, maybe the oil is warming and detecting the transmission & nbsp ;?
walla my brother factory I guess why it should not be overheated, I think the oil will be hot: I don't know, in other words, maybe the oil warms up without getting too hot, in my 2 gears & nbsp;
08.05.2020 17:02 # 15
berk2309
Now in Cyprus, there is something in the water, they use water that is filled with tap water in the water. cannot prevent overheating and warming & nbsp; new solenoids or medicine & nbsp;
08.05.2020 17:02 # 16
volkan22
The solenoids start very well, the vehicle is serial, but when it is pressed for a certain period of time, the sport never does when the snow light is cold, it never warms when it warms.
I also 1.2.3. I throw it myself, I don't live wurunt, when I don't press it, there is never wurunt in the D position. & nbsp; Also, I think he has a water inlet box in his transmission, the room does not cool properly, probably he may have a problem with our friend.
08.05.2020 17:02 # 17
berk2309
As I said, the problem of heat exchanger may be oil sogutmuyo & nbsp;
08.05.2020 17:02 # 18
berk2309
The master at the ABC peugeot service told me to take the thermostat out in the summer and there is no harm. I am boiling in Cyprus.
08.05.2020 17:02 # 19
volkan22
my thermostat socket is already good, the temperature of the car is very good even 90 carsida 90 is a little late, sometimes I think that the pipes to the transmission are radiators or something, I always understand the vehicle & nbsp;
water hoses of the engine can be clogged. We will get them done, but if the water hoses that go to the auto transmission are not checked, the box that my harness inside should have cooled the transmission is not checked, but I do not get this knock as long as I do not hit it, I am getting sick, I feel it is painful, but in the end, I feel that I have a knock on my face ... div>
08.05.2020 17:02 # 20
berk2309
I think it may be in the oil, it may be from the brain in the hydro block, or it may be from the small solenoids there, I think it is hard.
Page : / 2
