After Removing and Installing Throat Butterfly?
08.05.2020 18:03 # 1
By_Akademisyen
Today, the master of the industry took off the throat butterfly of my vehicle, sprayed on the lining and cleaned it again. I encountered while browsing the internet after removing and inserting the throat butterfly, it had to be adjusted on the computer. Is this true? I regretted what I had read on the Internet and wish I had stopped it. Do you think it causes problems? Do I need to make an idle adjustment because it is removed and installed?
08.05.2020 18:03 # 2
ahmed206
I think there is no such thing. But it may also vary from vehicle to vehicle. Write a model of your vehicle first, a master comes out of course
08.05.2020 18:03 # 3
Ahmet_ach
If the accelerator pedal is electronic, adaptation is necessary, if it is wired, you don't need to do anything.
08.05.2020 18:03 # 4
By_Akademisyen
Vehicle 2006 model, 206 1.4 petrol. Is it tellimim, is it electronic? the by_akademisy 2013-11-10 01:32:52
08.05.2020 18:03 # 5
sezar206
I got it cleaned twice. You don't need to do anything. Is there a difference in your vehicle?
08.05.2020 18:03 # 6
By_Akademisyen
I have come home from seconds after having it done today.
08.05.2020 18:03 # 7
ahmed206
1. Relax, there is probably no such thing in your car.
2. I guess you do not understand much of these things and believe everything that is said, I never underestimate it, just do not believe the masters. If we were to do what every master said, most of us would not even be able to get on our cars properly due to expenses.
3. Drive your vehicle to someone who understands once in a while and understand if there is a problem.
4. Somebody tell me how to cut the whisper from that gearshift :)
08.05.2020 18:03 # 8
error
[QUOTE = I anon]
welded together LOL
What do you mean by whine?
08.05.2020 18:03 # 9
Aziz
Why did he pull out the throat butterfly, it would be enough to unplug the air filter on the butterfly, it wouldn't be a problem, but do not spray the lining spray again, it may cause bad results ... Saint 2013-11-10 13:45:16
08.05.2020 18:03 # 10
ahmed206
[QUOTE = error] [QUOTE = I anon]
welded together LOL
we boil it and let's see if we have money we hope we can solve it :)
when the vibration increases, it sounds, but it's not annoying.
08.05.2020 18:03 # 11
tigerland
The throttle of the vehicle is electronic. If the position is broken, the idle runs. It is connected to the computer and the vehicle is set below 30 degrees and the position is adjusted again. FYI friends tigerland 2013-11-12 15:04:28
