after maintenance !!!!
08.05.2020 16:12 # 1
efsanemurat
hello friends 10 days ago I changed the oil of the car (castrol edge full synthetic) & nbsp; oil filter and air filter, I thought the car will come to life after the maintenance, but it did not matter much, on the contrary, the sound of the car changed while it was working like it was getting air from somewhere but it does not make it constantly .bide the car I tried the last gas in it I was the only one on the flat road 170 did not exceed my car 225 45 17 tires have misleading this speed indicator shows how much it shows everyone good forms
08.05.2020 16:12 # 2
oguzhan29
Keep the subject up to date, knowledgeable friends will help you
08.05.2020 16:12 # 3
Long Beach
What is the machine?
Replacing oil + filter is not chip tuning, it is a result of periodic maintenance, whether it be a revival (!). He has to test it, otherwise it's not a job to be memorized. Some will say spark plug, some don't ignite. some fuel pump, some exhaust ... you will spend a lot of money on the empty pipe.
08.05.2020 16:12 # 4
efsanemurat
the sound does not come from the exhaust, it comes with the normal engine sound from the front. As you said, we are right, sometimes we do not work.
08.05.2020 16:12 # 5
How many numbers from the Edge series have been used as engine oil?
08.05.2020 16:12 # 6
sedataksu
I know that the car's 1.4 hdi xr original tire size is 195 * 65 * 15. When you make the tire size 225 * 45 * 17, it makes 3 differences per thousand on the speedometer. This is not a difference you can understand from the needle. tires and wheels will definitely affect the traction of the vehicle. If you want to see different sizes, you can look at the link below. "target =" _ blank "rel =" nofollow "> http://www.lastix.com/haberler.asp?nws=14
08.05.2020 16:12 # 7
efsanemurat
I used castrol edge 5w-40 as engine oil
08.05.2020 16:12 # 8
It is very strange that the vehicle does not exceed 170, so there is something that prevents the vehicle from accelerating, I do not think it will be related to the tires.
08.05.2020 16:12 # 9
I think it is very normal that the vehicle does not exceed 1.4se 170i. When it comes to the sound event, there is a forward pipe that comes to the air filter from the back, your left headlight ends there. Check it out, it's okay to breathe in the air.
08.05.2020 16:12 # 10
efsanemurat
okay thank you it was actually on my mind but i didnt think it will be my first job to check it tomorrow
08.05.2020 16:12 # 11
[QUOTE = HuseyinTurk] I think it is very normal that the vehicle does not exceed 1.4se 170i.When it comes to the sound event, there is a pipe that comes forward from the back to the air filter, the left headlight ends there. It is very sweet, but it is safe from hot weather. Check it out. It is the same thing that happened to me.
08.05.2020 16:12 # 12
efsanemurat
I made the dial 220 engine just 5000 km ago, I haven't pressed it since then, but the engine has not been opened yet
08.05.2020 16:12 # 13
Master, the car in me has not been more than 20,000 km, they have laid the vehicle in the garage, despite it, it sees 180 very comfortably. If this car is not opened, you should have at least 200 revolutions. Probably there is a problem that prevents acceleration ...
08.05.2020 16:12 # 14
I Love My Pug
[QUOTE = HuseyinTurk] I think it is very normal that the vehicle does not exceed 1.4se 170i.When it comes to the sound event, there is a pipe that comes forward from the back of the air filter, the left headlight ends there. It is very sweet, but it is safe from hot weather. Check it out. It is the same thing happened to me. [/ QUOTE]
& nbsp;
& nbsp;
Make it easy.
08.05.2020 16:12 # 15
I Love My Pug
[QUOTE = legendary] dial 220 engine just made 5000 km ago I haven't tightened the car since then, the engine has not been turned on yet [/ QUOTE]
& nbsp; < / DIV>
Sorry, then there might be a problem ..
08.05.2020 16:12 # 16
Friends, why was there 220 dials? I was very curious.
08.05.2020 16:12 # 17
34sea45
[QUOTE = HeRo1727]
The master in my car did not have more than 20,000 km of cars, they have laid the car in front of the garage, it seems 180 very comfortable. If this car is not opened, you should have at least 200 revolutions. Probably preventing acceleration ... < / p> [/ QUOTE]
I click on the bar 1.4 The tool should see this very comfortably 200 of them are sure to have a problem somewhere
08.05.2020 16:12 # 18
I Love My Pug
[QUOTE = HeRo1727] Guys, I was so curious why there are 220 dials. He put the 220 text in order to get air in there ... [/ QUOTE]
& nbsp;
There is no condition that my brother will press 220 because I have 220, I know that the factory is already over dial. I. My brother has palio 1.2 8V tenth dial 220 but does not exceed 160 car :))
08.05.2020 16:12 # 19
The dial values of each model of the 307 are the same. It does not mean that every engine will make the same speed. Factors such as buy zero plug turbo etc from the factory are at a very important speed.
08.05.2020 16:12 # 20
I Love My Pug
[QUOTE = HuseyinTurk] The dial values of each model of the 307 are the same. It does not mean that every engine will make the same speed. I have been using this vehicle for 4 years to see 220 of us, but for a long flat or downhill. No matter how new you want, you can buy from the factory, such as zero plug turbo etc. The speed of my car's turbocharger was disabled, I never forget from the brain, I go to the taxi from the estuary. >
& nbsp;
"Grin" & nbsp; lada it goes bad
Page : / 2
