advice for headlight fading
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:38 # 1
maestro
Friends get a really good result with water sanding and then pastry polish for fading. I have done this work many times. After polishing and polishing, I covered it with headlight film for about 2 months and I would recommend that there was no fading in the headlight even though the weather was burning sun.
At first, I tried to make it as a single piece, but since the 307 headlight was angled, I made it in 2 long pieces.
Actually, I thought from the colored headlight films to the color of the car, but I got it transparent because I thought the police would cause problems.
08.05.2020 17:38 # 2
maestro
You apply both the headlight and the film by wetting it with a glass of glass, and then you shoot the bubbles with a credit card-like plastic. By the way, you heat it with a blow dryer. There is no other cost.
http://www.youtube.com/watch?v=ahıxc9reze to
08.05.2020 17:38 # 3
umut_25
[QUOTE = maestro] Guys, a really good result is achieved with water sanding afterwards, and then pastry polish. I did this job many times. I ordered and polished and polished the headlight well and covered it with headlight film for about 2 months and I would recommend that there was no fading in the headlight even though the weather was burning sun.
First of all, thank you for your useful information. I have a question. Do you sand the headlights from the outside or from inside? How open are you if you are sincere?
08.05.2020 17:38 # 4
umut_25
[QUOTE]
Then why can I do it? Why should I travel? :) Where do I find the water sander?
08.05.2020 17:38 # 5
umut_25
[QUOTE = onurazgin] in my opinion, no getting into the sanding business respectively;
-thick cake,
- medium cake;
thin cake;
-polish
If you apply it for 3-4 minutes at every stage by pressing it well, you will get great results.
I found a video on the net. My headlights are not so lousy. But the application in this video seemed simpler. The man is doing very well. He uses a water sander. Take a look
http://www.youtube.com/watch?v=dnıewoxd70y
08.05.2020 17:38 # 6
umut_25
[QUOTE] the protective film is wearing out, it turns yellow every 2 months when it gets worn .. but again it is up to you
Hmm, with the experience, you are a fixed diode :) Although there is no original headlight in my vehicle, there is angel but there is a protective film on it.
So what is the plast x of meugars you say . Is the headlight cleaning lotion or something?
08.05.2020 17:38 # 7
umut_25
08.05.2020 17:38 # 8
Gokhan Cetin
[QUOTE = Maestro]
http://www.youtube.com/watch?v=AhIxc9RezeA [/ QUOTE]
Thank you very much.
08.05.2020 17:38 # 9
maestro
http://www.hepsiburada.com/liste/m-head-seffaf-far-filmi-30-cm-x-1-metre-1190403-/productdetails.aspx?productıd=otmbrkbr1190403&categoryıd=20025764
This is the headlight film I bought.
My advice to friends who will do this sanding or polishing is to pay attention to whether the problem is from inside or outside.
08.05.2020 17:38 # 10
samet206
It has been a good precaution before I opened the subject, thanks to my friends helped water sanding cake polishing process, but as you said, my car stood on the street matting has occurred. I am thinking of replacing this headlight with the original. After the change, I can apply this foil process on both headlights thanks.
08.05.2020 17:38 # 11
umut_25
[QUOTE = onurazgin] [QUOTE = umut_25] [QUOTE = onurazgin] this ad is not a real application video, the ones who made it professional also .. I told you the easy way: D: D actually meugars have the product called plast x if you can find it best. There are many videos available from me. I advise you to use water sandpaper. The protective film is wearing out, it turns yellow every 2 months. But it is up to you again.
a protector with headlight cleaning varnish does not work .. that is when you go .. [/ QUOTE]
I will take a photo of my headlights in a few days and I will send you a special message. We follow a path according to him. You say that the product is useless. Well, do you think the other product will work by applying it alone?
