advice for deformations?
08.05.2020 18:17 # 1
blue42
friends black bands around the glass & nbsp; the lightly deformed doors look bad, is it easy to stick the new one? One steering wheel deformity - do you have any suggestions for seat-to-mouth deformity?
08.05.2020 18:17 # 2
tongucuk
Do you have a chance to put a picture when you say around the glass
08.05.2020 18:17 # 3
blue42
There is no picture at the moment, I say the black tape coating on the pole between the front door and the back door & nbsp;
08.05.2020 18:17 # 4
tongucuk
heee, if you want something easy to clean, you should first remove the old foils with a heat gun and then clean the surface of the residual tape with alcohol or spirits. Apply with foil will be like the original
08.05.2020 18:17 # 5
tongucuk
In cigarette burn, if it has not pierced the seat and is only the removal of the yellowing of the upholstery, I have heard that only sanding the burned area with a sandpaper in a circular way solves a bit of a problem, but I have not tried it.
08.05.2020 18:17 # 6
blue42
There is no cure for him as he made a hole as much as the tip of the cigarette?
08.05.2020 18:17 # 7
rizeli_53
as far as i know they were making holes in sonax. but it can be expensive.
