Advice for care
08.05.2020 19:36 # 1
darklebron
Hello friends. Actually, I opened the subject for advice, not suggestions. My vehicle has 100.000 maintenance at 99 thousand now, normal 10,000 vehicle maintenance + crankcase protection + spark plug replacement + small things, if I make them in the private service I go, it costs 400 to 450 workmanship but when I collect the things from the net from peugeot's market of course, it keeps about 300 figure. now my question is how much workmanship they want to do if i get them, and they do it is also a small question.
08.05.2020 19:36 # 2
badcombatant
They do special services, they only receive labor prices, but I don't think authorized services will do. Since they give "supposed guarantee" for the materials they change and the workmanship they do, they do not take such responsibility by using materials that come from the outside.
The flickering problem is also likely to be checked in coming due to brake discs or pads.
08.05.2020 19:36 # 3
darklebron
Well, how much workmanship they want more or less at the same price. Also, the importance of originality in disc and pads
08.05.2020 19:36 # 4
badcombatant
I guess your car has almost no price information about gasoline and gasoline vehicles. I don't mean anything wrong.
Experience and fixed, the subject of pad and disc should be original first. There are only 4 tires connecting the vehicle to the road. Thumbs Up
08.05.2020 19:36 # 5
darklebron
The brake discs have never been turned before. I wonder if it will be turned once before.
08.05.2020 19:36 # 6
[QUOTE = darklebron] Brake discs have never been turned before, I wonder if it will be turned once before [/ QUOTE]
Turning is done according to the thickness and condition of the disc. There is no excessive curvature and there is nothing to do if there is not enough thickness. Unfortunately, they need 15-20 TL per head. two discs cost 40 TL. If you have any problems with zeros between 100-150 TL, my advice is to replace it with a new one.
08.05.2020 19:36 # 7
darklebron
100-150 TL, rıw brand side industry, I saw them in me, would you recommend me?
08.05.2020 19:36 # 8
darklebron
actual
08.05.2020 19:36 # 9
I do not think it will be a problem, my teacher originals start from around 180 TL. There is a peer-to-peugeot peugeot, which is generally more affordable prices. Of course, budget is important, but if you want my head to be comfortable. I would say the original forehead. I personally prefer the one that I use in my previous vehicles, do not forget to replace the linings when the discs are changed. Good forums.
08.05.2020 19:36 # 10
darklebron
Thanks.
08.05.2020 19:36 # 11
we had the same problems in our neighbor, and I did not hear any problems after that. Of course a bit of luck :)
08.05.2020 19:36 # 12
darklebron
Yes, you are right
