Adjustable American parking problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 21:00 # 1
Ugurcan57
Have a good day
In July, we bought 3 friends and 3 different cars from the same American parking module.
While there was still no problem in any of my friends, I explained the accessories we bought one day for no reason, my module was replaced with the same branded product.
Then, when I went to have another electrician install the module, it said that this module would turn on again in 406s, it was not logical for me that the electrical installations of these vehicles were different from the others, but I wanted to ask you, could anyone have come to the beginning, or could the master be right?
08.05.2020 21:00 # 2
HasGur
[QUOTE = Ugurcan57] Good day
It did not make sense to me that when I went to have another electrician install the module, it said that this module would turn on again in the 406s and that the electrical installations of these vehicles were different from others.
Yes, it is an illogical statement ... As if they have distributed master certificate to anyone who wants it!
I wish you had asked what the difference was ... did the 406s double battery work with 24 volts?
08.05.2020 21:00 # 3
Ugurcan57
I am thinking of appreciating tomorrow, I would like to ask another master, but do you have an American parking node set in your vehicle?
08.05.2020 21:00 # 4
Alicilik
[QUOTE = Ugurcan57] I am planning to have a tomorrow.
How many bulbs are connected at the output of the module?
I connected more than 100 modules, but I had no problems.
08.05.2020 21:00 # 5
Ugurcan57
signal and parking bulbs only
08.05.2020 21:00 # 6
Ugurcan57
Today, I was going to have the module that we bought right now, it seems that my friend who used the same module had burned in the module in his car, as of yesterday, that this material of this brand is problematic, let me tell you.
08.05.2020 21:00 # 7
Alicilik
It is normal for the module to burn out over time if you are using it above the output power. I also use 2 * 26w output module, one big signal (21w), one small signal (5w) bulb, one side support. If you connect 2 pieces of 21w power to this output, the module will burn out over time.
In American parking modules, do not connect any additional bulbs other than a single flush signal except for a single bulb.
