adding too much oil
08.05.2020 17:00 # 1
falan
friends, I changed the oil of the car, but when i pulled the stick, i saw that i put too much oil .. 3-4 cm above the max line .. now my question is how do i get the excess oil?
08.05.2020 17:00 # 2
monur
Since excessive pressure will occur, the power show starts between the crank seal, the crankcase gasket, the top cap gasket, the rocker cap gasket, whichever is durable, the other or the others explode, and the excess oil bursts out. 3-4 centimeters you are talking about is equivalent to half a kilo and more of fat.
08.05.2020 17:00 # 3
falan
Clicks for the answer .. I know that it may have a few damages. I asked;) so I don't know how to get the excess oil in it ...
08.05.2020 17:00 # 4
You can remove the crankcase plug by loosening. Another way is not possible.
08.05.2020 17:00 # 5
hakan38
brother, the same problem happened with me 4 liter of oil came more than 1 liter of oil from the crankcase. As your friend summed up very well :)
08.05.2020 17:00 # 6
_pathfinder_
If my master car has crankcase protection, lift etc will require effort and a little money. Instead, go to a medium oil change shop. You do not have to pull half a liter and do your job.
08.05.2020 17:00 # 7
falan
Just like friends, there was all sorts of damage to the oil. I said, let's open a master stopper because I couldn't find a place with an oil extraction machine in the industry. I said okay. almost & nbsp; 1 liter & nbsp; oil came out .. & nbsp; thank you for the cvp everyone ..
