Adding to the Sound System
08.05.2020 15:12 # 1
splashstyle
The installation in my vehicle is now;
Pioneer 1200 Tape
16cm Kicker 650.2 Mid
Kicker Dx 200.4 Amplifier
Kicker Comp 12 Sub
I will add another Comp 12 to this system and have the mid doors attached. So I will also buy mono amps .. Midler is not a problem, but I need an amp as an idea :)
2 pieces of Kicker Comp 12 will you feed 30 cm bass a mono amp?
Actually, I have some thoughts on my head.
Jbl 3501
Jbl 7001
Jbl 601.1
Cadence Zrs 1502
Soundmagus Dk 1200
M-Acoustic M 1000.1D
Soundmagus X402
Soundmagus X801
Soundmagus Dk 1800
There are a lot of options, but for these 2 bass, I would prefer the most affordable and get the best performance. Actually, I have not to exceed 300 in my mind.
Thanks in advance.
08.05.2020 15:12 # 2
tigerland
Enjoy Jbl 601.1 then enjoy it :) Do you have that much sound contest :)
tigerland 2011-03-30 15:24:29
08.05.2020 15:12 # 3
splashstyle
I do not want anything booming or I just can't get the strike and bass properly.
08.05.2020 15:12 # 4
tigerland
JBL mono amps do a good job.
08.05.2020 15:12 # 5
serkan24577
jbl mono amp is solid i have jbl 601.1 i feed the kicker l5 with this monster comes out :)
08.05.2020 15:12 # 6
splashstyle
If I throw the kicker dx 200.4 and replace it with Jbl 5355 and have a double bass, what is the performance?
08.05.2020 15:12 # 7
selcuk-307
[QUOTE = splashstyle] If I throw the Kicker dx 200.4 and get Jbl 5355 instead, what is the chance of double bass and how is the performance? [/ QUOTE]
The model jbl 5355 is an amplifier with 4stereo + 1mono output. I don't think its performance will be satisfying for 2 bass. I think you wanted to buy this model just to use an amp.
If you want an amp, I would recommend Xetec 355.6.
If you are going to get mono amp with second amp intent, I definitely recommend JBL 14001. as I understand you are not comfortable, you want to add something to the next year. I recommend not to buy medium quality products for it.
08.05.2020 15:12 # 8
dinoco
I have 5355 jbl for sale very clean if you want for sale my friend price is 300 TL
08.05.2020 15:12 # 9
splashstyle
thanks I have used my anfi preference since 601.1 for the information.
I have one more question. Is it possible to install the rear columns 13cm but 16 cm 650.2 kicker in my 206 van vehicle?
08.05.2020 15:12 # 10
[QUOTE = splashstyle] thanks I have used my amp preference 601.1 for information.
I have one more question. Is it possible to install the rear columns 13cm but 16 cm 650.2 kicker in my 206 van vehicle? Is it possible? [/ QUOTE]
Give me the money, they wear everything, but you pity on the door. Professional brands such as VIBE have 13 cm Components and will make you very satisfied.
08.05.2020 15:12 # 11
splashstyle
I am using 2 kicker comp 12 with 601.1 amphitheater. There is a smell like burnt smell in high volume :)))
Do you think the bass should be changed? If yes, what would be the ideal bass for 601.1 bass budget 300 TL
08.05.2020 15:12 # 12
dinoco
[QUOTE = splashstyle] I use 2 kicker comp 12 with 601.1 amplifier, it smells like burnt smell in high volume :)))
Do you think the bass should be changed? If yes, what would be the ideal bass for 601.1 bass budget 300 tl [/ QUOTE]
If you can not burn those comps with 601, there is a wrong installation .. or look at the gain settings .. but this is a psychological thing.
As I said, you should have your fuse checked. Also, the cable from the aquarium was not 10 awg. You are driving 2 bass.
08.05.2020 15:12 # 13
dinoco
[QUOTE = erhanomer] [QUOTE = splashstyle] thanks I have used my amp preference for 601.1 for information.
If you want to use a comp to be stero anfi. Would it be 16 cm to 13? but the workmanship must be nice. It wouldn't be possible if the vehicle was not a van because the rear windows do not hurt because of the magnitude of the magnets ..
