Adding steering fluid
08.05.2020 20:56 # 1
Karacocuk24
I said let me check it out today, when I remove the oil cap, I think the oil remained at the bottom add in the measurement cube, I think it is necessary to add it, but what should I add? 2001 model 1.4 petrol model Karacocuk24 2018-06-21 21:34:40
08.05.2020 20:56 # 2
As far as I can remember, there will be 3 lines, the middle level will be sufficient.
08.05.2020 20:56 # 3
Karacocuk24
[QUOTE = sonerkyl] As I recall, there will be 3 lines, the middle level will be sufficient.
[/ QUOTE] soner link does not open noble do i have this oil colors i want to learn i need to add color to my gorem i need to add the oil name from gas station
08.05.2020 20:56 # 4
Steering hydraulic oils are referred to as ATF, there is a steering symbol on the box. only a different oil is used on the power steering. But there is no need for our vehicles. the ones in the gas stations are usually very old.
08.05.2020 20:56 # 5
Karacocuk24
[QUOTE = sonerkyl] Steering hydraulic oils are referred to as ATF, the steering wheel symbol is on the box. only a different oil is used on the power steering. But there is no need for our vehicles. the ones in gas stations are usually very old. If you take my 3-4 year old particle, it is better [/ QUOTE] thank you my brother sagolasin
08.05.2020 20:56 # 6
x571
[QUOTE = Karacocuk24] I said let me check it out today, when I lift the oil cover, I think it is necessary to add the oil in the bottom of the measurement bar, but it is necessary to add 2001 model 1.4 petrol model [/ QUOTE]
Atf you will add oil, you can even get it from gasoline, but it should not decrease oil. there is a leak. look at it first.
08.05.2020 20:56 # 7
Karacocuk24
[QUOTE = x571] [QUOTE = Karacocuk24] I said let me check it out today when I remove the oil cap, I think it is necessary to add oil in the bottom of the measurement bar, but I need to add 2001 model 1.4 petrol model [/ QUOTE]
[/ QUOTE] I do not know if there is a leg, the truth is that the car has been standing for me for 3 years.
