Adding excess oil
08.05.2020 19:41 # 1
ekinoks44
Hello friends. After using 5000 km of oil from my vehicle, I noticed that it was slightly below the minimum line and went to add oil to the gasoline. The guy at the gas station told me that I had to add 2LT, but I told him to add 1LT because it was too much for me. When I came home and checked the bar, I noticed that the oil was 0.5 cm above the maximum line. I did not follow the mind of God and add 2LT. Is this a problem now? Already after 2-3 weeks, I will go a long way, about 1200 km, will this excess go? (My vehicle is gasoline / LPG)
08.05.2020 19:41 # 2
ssakyel
Hello, I had a similar problem recently, they put too much oil on the engine, I experienced problems like self-gasing, idling irregularity.It also damaged other parts. I made a lot of expenses until I understood. I wish you a pleasant journey, an accident-free ride.
08.05.2020 19:41 # 3
talip206
Every time I go to change the oil, they try to drain 4 liters. I add 3 liters each time, then add a little more depending on the condition of the bar. If the filter does not change, 3 liters of oil should be added, and if it does, 3.25 liters of oil should be added.
08.05.2020 19:41 # 4
akk0212
I don't think there is too much,
08.05.2020 19:41 # 5
ekinoks44
I was going to get the excess, but I gave up. But I will do such things myself again.
08.05.2020 19:41 # 6
Barut
It doesn't look too much. In addition, putting excess oil explodes the seals.
