Activating 307 fog lights
08.05.2020 16:25 # 1
efsanemurat
hello guys, I noticed something while looking at the car today, when the fog lamp turns on, the back lights are on, but the lights do not light up, when I check it thoroughly, there is a fog light in front of the headlights, I searched a little, our vehicles are in front of them, there is a fog light up to the lamp but there is no indicator on the screen. There is a burning light on the back. If we pull a connection to the cable from the fog light on the front to the rear fog, will it burn in the front when I burn the back.
08.05.2020 16:25 # 2
gozem
The most logical thing is to draw a line to the front fog from behind. Otherwise, if you try to buy pp2000kol, it will be more expensive. 0 "align =" middle "/>
08.05.2020 16:25 # 3
swat_407
If you turn the headlamp knob back from the left arm, the front fog lamps will light up if you turn it forward and a sign will appear on the screen. If you want a try.
08.05.2020 16:25 # 4
efsanemurat
I tried a lot, only the backs were burned and only the rear fog light sign appeared on the screen.
08.05.2020 16:25 # 5
VEDATDINC
To activate the front fog lights, you have to pull the cable from the rear fog or BSI J01 in your vehicle there is no other solution
08.05.2020 16:25 # 6
efsanemurat
everybody agrees with me I will find a good electrician and pull wires from the rear fog
08.05.2020 16:25 # 7
Vdtars
hello friends in my car there is fog in the headlight is not burning the rear fog and show gede is burning
08.05.2020 16:25 # 8
Orcun.Dmr
Com2000 is not necessary to activate the front fog lights, friends, stay away from the masters who say it will change. When connected to the vehicle with PP2000 and activating the front fog light from the brain, it turns on the fuse box inside the engine and your fog light works.
08.05.2020 16:25 # 9
In addition, in old cases, the fog light is in the headlight.
